Np 242 Vs Np 231
A 249 chain and sprocket with front out put shaft will give you a 1.25"chain and 32 spline front out put. The same parts from an np241dhd will push the chain to 1.5". I'm going with the 1.5"chain and 32 spline front output on mine for the MJ. Just because I already have the parys in the garage.
  • 1 year later...
There are things you can do to the 242 as well. Using parts from a NV242 DHD (used in diesel Dodges) or the version they used Humvees behind 6.5L turbo diesels can give you the strength (wider chain, etc) WJs with 242 replaced the open carrier with a Torsen limited slip unit.
I was not aware of this....
May have to take a second look at the 242.
Not quite. WJ's use wheel speed sensors not t case sensor. So there's no port cast out. It may be possible to swap cone but Idk. And a 242 is a 242. Just that. All years are essentially the same. The one your thinking of is a 247/249. Both of which don't have a 2wd option. Only 4all-N-4lo
