No Windshield Wipers
Tightened up my steering column, plugged all my connectors back in at the bottom of the column and now my wipers don't work. Blinkers, turn signals, and brights still work, but Not my wipers. AFAIK none of the column internals control the wipers, the switch is inside the "blinker arm", and I'm 99% sure all my connectors are plugged in at the bottom of the column, the only ones not plugged in are female 2prong connectors that I can't find any male ends for. Any ideas on what to check? Hard to drive in the snow and freezing rain with no wipers
Do you have a setting for intermittent wiper?  If so, the module underneath the dash may have just coincidentally took a dump.  Best way to tell is unplug both ends and mate each plug together.  You'll only have low and high settings in this case, but it should work if that's the problem.
