Zebvance Posted February 1, 2014 Posted February 1, 2014 I'm replacing all the pulleys on my mj and I'm having trouble finding the ac bypass bracket pulley. The truck did not come with ac from the factory and had this dummy bracket and pulley instead. I have went to orilies and they have no record of the part. If anybody knows a auto part store that I can get it, it would be helpful.
dasbulliwagen Posted February 1, 2014 Posted February 1, 2014 Not sure if the 4.0 is like my 2.5, but when I did mine, there was a fake pulley for the P/S that it didnt have, but for the AC the belt routing was just different, and it didnt have a dummy pulley there. WHen I added the AC and P/S I just added the P/S pump and compressor bracket and routed the new belt appropriately.
Zebvance Posted February 1, 2014 Author Posted February 1, 2014 Dayco 89012...got mine from amazon That does not seem to be the right pully. It is 90 mm, the one is have measures 101mm.
HOrnbrod Posted February 1, 2014 Posted February 1, 2014 Looks like it's part number J3239821, 100mm. Try searching for a better price. If this one is correct, it's pretty easy to change the bearing in it. Let me know; I've got the p/n for the bearing somewhere. http://www.carid.com/1987-jeep-wrangler-suspension-systems/crown-suspension-systems-16682199.html
Zebvance Posted February 1, 2014 Author Posted February 1, 2014 Looks like I found the exact part with the part number 53002903, the stealership Has it for 48$, I'm going to see if I can find it cheaper around town first.
carnuck Posted February 12, 2014 Posted February 12, 2014 That is 90mm. Try AC Delco 1520677 or Napa TEM 209756
