Cps Air Gap
I did the "open-the-mounting-hole" and the "advance mod" on a new NAPA CPS. After I replaced it and started the engine I heard a not-so-loud buzzing sound for about 10 seconds then the noise faded away. Engine ran fine. I was thinking perhaps there was slight contact between the CPS and flywheel. I had also put some duct tape on the plastic cover that the CPS fits thru to keep things from falling thru so maybe a piece of that got shoved thru the hole during installation and was rubbing the flywheel.
As a side note, replacing the CPS on a stock '89 MJ 4.0 with BA10/5 is a pain in the tuckus! Detaching the front driveshaft from the front diff and swing it out of the way gave me some additional elbow room. When I did the advance mod the plastic housing developed a faint hairline crack. I encased the plastic in epoxy it before installation. Hope it doesn't cause future problems.
Just drilled the upper hole?
I have heard CPSs that touched the flywheel before. It's not "not so loud".
Have you checked your CPS output?
I also remove the front end of the driveshaft for more working room.
I drilled the upper hole only.
Are you saying that CPS touching flywheel makes a substantial noise? In your case did it quiet down pretty quickly or did it continue?
I have not yet checked the CPS voltage. Will this weekend.
If voltage checks out would you say everything should be good-good?
Yep. Loud as hell !!!
Should be great. Just curious as to the reading you get.
Very interesting. I was under the impression that the tip was right over the teeth of the flywheel.
Hang around Hornbrod and me and you'll be exposed to many myth busting things.
I'll bust a myth........
That you can actually index the distributor on a 2.5.........no  can do.
Pulled mine out tonight.........distributor is fixed.....rotor at 6 Oclock......that's it.
