coyote kid Posted January 12, 2014 Share Posted January 12, 2014 Could a blown manifold gasket cause rapid overheating like in 5 minutes ? Link to comment Share on other sites More sharing options...
coyote kid Posted January 12, 2014 Author Share Posted January 12, 2014 Its a 88 2.5 Link to comment Share on other sites More sharing options...
jimoshel Posted January 12, 2014 Share Posted January 12, 2014 I don't see how it could. However being a Jeep I wouldn't rule it out. A stuck thermostat could do it. Link to comment Share on other sites More sharing options...
Blaine Posted January 12, 2014 Share Posted January 12, 2014 :agree: also could be clogged radiator and/or hoses, blown head gasket. hard to tell without proper diagnosis. i know when my head gasket went i couldnt keep my truck running for 5 minutes either, started blowing out steam and coolant. Link to comment Share on other sites More sharing options...
carnuck Posted January 18, 2014 Share Posted January 18, 2014 IIRC the 2.5L has a water passage? If so, the water/antifreeze can be sucked into the motor. Link to comment Share on other sites More sharing options...
big66440 Posted January 25, 2014 Share Posted January 25, 2014 I would do a block test to rule out the head gasket, you can rent the kit at vatozone and it's very easy to do, also just because a water pump is not leaking doesn't mean it's good I've pulled water pumps off cars were the impeller is so rusted and far gone it looked like a ninja star and wouldn't circulate water anymore. Link to comment Share on other sites More sharing options...
yxmj Posted January 25, 2014 Share Posted January 25, 2014 I would do a block test to rule out the head gasket, you can rent the kit at vatozone and it's very easy to do, also just because a water pump is not leaking doesn't mean it's good I've pulled water pumps off cars were the impeller is so rusted and far gone it looked like a ninja star and wouldn't circulate water anymore. Take a hard look here.... my wife is driving a cherry 2000 XJ that i bought for $700 cash......Original owner had an assessment from their mechanic of a blown rear end and blown head gasket....$3800 in repairs......I drove it home......replaced the 2 rear axle seals......and the "ninja" water pump.......she drives it to this day.....one of the most powerful 4L i have ever driven :thumbsup: Link to comment Share on other sites More sharing options...
