86 Comanche Motor Swap
Are you sure its a 4.3 and not a 2.8? I think the 4.3 and 350 use the same motor mounts. A long time ago I was involved in removing a Cutlas v6 (3.8 I think) and installing a v8. We reused the motor mounts and even the exhaust system was the same. The Y pipe attached to the v6 manifolds in the same spot as the v8. It may be easy it all depends on how the 4.3 was installed. Post some pictures I would like to see it.
I'm sure its a 4.3 I have water in my exhaust and not sure if its the head or a cracked block.i love the rig and want to fix it. I guess ill have to open it up and research more. I don't have a good place to work on it. its outside and the weather in Oregon right now is bad. I should mabe just repair or replace my 4.3
The 4.3 was never offered in the MJ by Jeep, so if you're certain it's a 4.3, it had to have been swapped in by someone. Did you do it, or was the swap done by a previous owner?
The 4.3L is basically a 350 V8 with two cylinders chopped off, so it sounds like transitioning to a V8 would be easy. However ... every XJ or MJ I've seen with a small-block Chevy engine in it has had severe overheating issues. For that reason, I would recommend that you stay with a 4.3L because it just might be a little easier to keep cool.
If it has as you say already been converted to a 4.3....any gm small block would be a minimal work bolt in....(obviously you would need V8 collectors for you exhaust.and any required computer controls) if overheating is a concern ......and to give you more space for the V8.....lose the mechanical fan and go with a electric set up......biggest one you can find or a dually.... would be perfect.......
