Comanchemodder Posted January 10, 2014 Share Posted January 10, 2014 Truck: 1987 2.5L 2WD Manual (AX-4) Symptoms: When driving in 3 & 4th gear, the engine starts to "stall", looses power. Push in the clutch and rev it a few times, and accelerate seems to cure it 50% of the time. but when cruising again, starts to stall. Seems ok under hard acceleration. But then there are times it ran ok. On the way home tonight kept rev'ing at stop lights since I didn't want it to die and not start. At home seemed to idle fine. Checked: 1) All four spark plugs look similar and of a light brown. They are "E3" plugs. 2) Checked TPS per Cruisers guide. Results: 1. Ground test: 0.9 ohms, stable on the "B"terminal. 2. A-B (reference) with key on: .33 volts 3. C-B (Output) with Key on: 5.07 volts. This seems wrong me since Cruiser's guide indicates my measurements are "opposite". I checked it twice: once and then again when I couldn't believe the numbers. I don't want to start adjusting until I figure out what's up with those TPS voltages. Also, anything else I should check first? Link to comment Share on other sites More sharing options...
yxmj Posted January 10, 2014 Share Posted January 10, 2014 Your motor has a intake that is "preheated" off of the normal heater hoses.....do you have a Temp gauge?....what are you running at? Link to comment Share on other sites More sharing options...
Comanchemodder Posted January 10, 2014 Author Share Posted January 10, 2014 Temp test: air temp 60 deg (no deep freeze here) I placed a thermocouple into the radiator hose where it enters the radiator (down stream from the thermostat). 60 deg (start up): idles good, using finger, actuate throttle cable about 3/16 inch to kick up the RPMs to 2000? 135 deg: I noticed the symptoms returned. Really chunky running. wants to stall. if i let it idle, it would have died. rev it a few times and it was okay. 160 deg. seemed to smooth out 190 deg. noticed some chunkiness again. 200 deg. shut it off This was done in the driveway, parked. Note, my Thermostat is a premium Gates 195 deg. I replaced last weekend or so. Link to comment Share on other sites More sharing options...
yxmj Posted January 10, 2014 Share Posted January 10, 2014 I have an infainfrared is there any way you can take your readings from the line to the throttle body.......that seems to be the angry one with mine.... :dunno: edit.....just seems to have "cold start" symptoms.....even though you ambiant temp is warmer than the room i am in now.... :thumbsup: Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 10, 2014 Share Posted January 10, 2014 You have a coolant temp sensor and an air temp sensor in the intake, have you replaced them? What about O2 sensor? Is there any kind of dead spot on the throttle? Link to comment Share on other sites More sharing options...
Comanchemodder Posted January 10, 2014 Author Share Posted January 10, 2014 The coolant temp sensor (CTS) reads "open circuit" ; should be less than 1000 ohms. The manifold air temp (MAT) reads "open circuit" ; should be less than 1000 ohms. That seems really strange to the point I wasn't sure if I was doing it right: 1) I disconnected the sensors and probed across the pins at the connector 2) I confirmed the ohm meter was working properly by touching probes together ( 0.00 ohm). ->same result "open circuit". O2 sensor was replaced last year. I have never tested the CTS before. No idea if they worked previously or not. Engine worked ok for the longest time; but these symptoms got really bad today all of a sudden. So bad I will need to drive my wife's truck to work tomorrow... Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted January 10, 2014 Share Posted January 10, 2014 I was wondering if anyone else was having these problems too. Mine isn't as bad it just does it in second gear mostly, until it is completely warmed up. I'll be keeping an eye on this, hopefully you get it resolved. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 10, 2014 Share Posted January 10, 2014 The CTS and IAT, along with the MAP share the same ground circuit. If you haven't already, refresh the firewall to head ground and the dipstick tube stud grounds. Link to comment Share on other sites More sharing options...
Comanchemodder Posted January 10, 2014 Author Share Posted January 10, 2014 About two months ago, I replaced my grounds with high-quality 4 AWG copper: http://www.kelleyswip.com/electric.html. This includes battery to dipstick and head to firewall cables. I will recheck the ohm to be sure. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 10, 2014 Share Posted January 10, 2014 What about the dipstick tube stud area though? Clean and shiny? Link to comment Share on other sites More sharing options...
Aurelio corso Posted January 10, 2014 Share Posted January 10, 2014 I have the same problem but only when the engine heats up it wants to buck and kick once in a while cold it runs great.I took it in for a compression check and 5 cylinders were above 100 and one was 75. Link to comment Share on other sites More sharing options...
Comanchemodder Posted January 13, 2014 Author Share Posted January 13, 2014 I replaced the CTS with the Autozone SU332. Note, after getting some erroneous readings from my cheapo Multimeter, I used the calibrated Fluke 87V here at work. The MAT sensor reads 3.4k ohm at 70 deg F. which agrees dead-on with Hornbrods spec table . So the MAT "seems" to be good. Driving to work today, it ran great. Ill report back in a couple of days. Note to self: make sure test equipment is reliable before spending money on parts! Link to comment Share on other sites More sharing options...
