Wrz Posted January 16, 2014 Share Posted January 16, 2014 Did you get the 4wd lever to line up with the console? I tried to install a 98 zj console and could not get both the shifters to line up Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 16, 2014 Author Share Posted January 16, 2014 no mines 2wd Link to comment Share on other sites More sharing options...
Wrz Posted January 17, 2014 Share Posted January 17, 2014 that makes scense, if you decide to fab up a secret compartment I hope you do a write up. Always wanted to do one of those Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 18, 2014 Author Share Posted January 18, 2014 Bond style... lol Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 20, 2014 Author Share Posted January 20, 2014 So I briefly considered selling the MJ (pleading temporary insanity) but have decided to keep it. I decided that if I am in fact going to keep it I am going to give it a full electrical overhaul and clean up my engine bay... Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 20, 2014 Author Share Posted January 20, 2014 The engine bay free of the old hacked n spliced harness: Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 20, 2014 Author Share Posted January 20, 2014 Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 20, 2014 Author Share Posted January 20, 2014 What quickly made the top of my $#!& list was the poorly engineered C101. The C101 is the junnction box on the drivers side firewall that the harness feeds in and out of. I have already done the C101 connector cleaning per forum advice but the more I read about it it just seemed entirely unnecessary and many have removed it entirely (including Chrystler just 2 years later) For reference, here is a picture of the C101 Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 20, 2014 Author Share Posted January 20, 2014 And this is a pic of the inside of mine while mounted in its stock location: Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 20, 2014 Author Share Posted January 20, 2014 Another problem I found was the crud in my fuse box connector: Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 20, 2014 Author Share Posted January 20, 2014 Initially I figured I would just give it a good cleaning but after I pulled the fuse box and saw more melted, corroded and jumpered connections I decided a new fuse box was in order. While mine functioned ok (a couple of fuses liked to fall out at random) I have never been a fan of it being mounted up under the dash, hidden in a dark jungle of wires and with my dash swap its even harder to try and crane my upper body into the footwell while holding a flashlight to try and check the fuses. A little research and a quick trip to the junk yard and I now have this: Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 20, 2014 Author Share Posted January 20, 2014 Surprisingly there were 8 XJ's in the yard so I found the best under hood fuse box available and grabbed a ton of fuses. This one is out of a 2000 sport. I also found my trucks twin! Ive only ever been able to find one other MJ in a yard so you can imagine my surprise seeing this beaut. Same motoe and trans so I snagged the speedo cable and valve cover plumbing. I sat there for quite a while going over every inch of it. It was nearly 100% complete, completely stock and only had 120k miles on it. It felt so strange sitting in it knowing this was my EXACT truck at some point... Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 20, 2014 Author Share Posted January 20, 2014 This is where I plan to mount my new fuse box. The little thing mounted to the inner fender well is an 85 Dodge voltage regulator. There are a few write ups on how to add it to your charging system and it works great Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 20, 2014 Author Share Posted January 20, 2014 C101 delete is almost finished, just have to finish soldering. Then I plan to go through every wire and remove every crimped connection and splice, solder and heat shrink them. Link to comment Share on other sites More sharing options...
88whitemanche Posted January 23, 2014 Share Posted January 23, 2014 Nice work...just noticed this truck was on the selling block on Craigslist....didn't know you were located in Florida.... Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 23, 2014 Author Share Posted January 23, 2014 Yeah I briefly considered selling it but I decided to keep it. I actually met up w a guy and was pretty emvarassed that so many things were left unfinished... Ive bought other peoples projects before. I won't sell one. Link to comment Share on other sites More sharing options...
SmthnD1ff Posted January 23, 2014 Author Share Posted January 23, 2014 As for the new harness progress is slow but steady. The ECU harness is pretty much done. I'm still mapping out the diagram for the PDC. You can't rush electrical work... Link to comment Share on other sites More sharing options...
SmthnD1ff Posted February 7, 2014 Author Share Posted February 7, 2014 So its been a while with little progress but my Stormtrooper is back on the road. I had one hell of a time going wire by wire and redoing this things entire harness but in the end its worth it. I still have a few bugs to work out vut here are a few pics for you photo nazis: Link to comment Share on other sites More sharing options...
