Shift Linkage Write Up
What I did was get rid of all the extra crap that has no business being in there. I've done a couple linkages like this now and they work great!
There was a write up on here a while ago that I pulled inspiration from... of course I can't find it right now though.
I'd love to see a write up for that.
I'm working on the same deal for both my XJ (trail rig/DD) and my MJ when I convert it. really it's just extending the stock shift arm below the body and either making or using a different range selector arm on the 'case.
I'm getting some custom arms cut but a YJ or S10 arm works just as well
Dang, that looks simple enough even for me.
Hardware store, threaded rod (or is that 2 bolts welded?), a couple of ball/johnny joint type swivels and some nylon washers with nuts.  Right??
Looks like the arm connected to the hand lever is extended, that's the part I'd need more info on.
You could use all-thread... I was just using what I had on hand. The lever from the shifter was extended down so the linkage was more in line to the transfer case. Also, I cut and tweaked the angle of the little arm on the t-case. Easy, easy.
  • 3 weeks later...
