Jeepman's Mj Grows Again
Yup It is a soft tri fold Extang trifecta. It wasn't easy
to find the right fitment. This one that I am most happy with is
From an 04-10 canyon/Colorado.
As for where I got it well it came from my distributor.
And thanks the rims are better looking then I expected they would look.
  • 5 months later...
I already have a WJ front D30 so I will be installing a set of Front WK SRT8 front Brembo's and custom make caliper brackets, it should actually be pretty easy but that will have to wait...
I recently lost #2 Cylinder and exploded the piston so I am expediting my 4.0L stroker (4.7) right now and Trans mods...
I really like the 18" rims and 35" tires.  Looks awesome.
With the 18" wheels, it really opens up the option of front brakes.
Your rear's are ?14" rotors.  You have to go 14" or 15" front rotors to keep a balance?
Here is what I am putting on the front of 'RaceJeep' that we street and autocross with-
2013 Jeep GC SRT8 6 piston calipers and Shelby GT500 14" rotors (5x4.5")
Looks good but I will be good with the matching front WK Brembo's and will upgrade all rotors to drilled and slotted eventually.
I will look into the 2013 calipers if they are 6 piston as the 2008 is only 4 piston front and rears.
  • 1 month later...
Well Now that My good Old 4.0L Engine Blew up I Have been finishing up my New 4.0L stroked to a 4.7 and eventually Supercharge it but that will likely be next years project...
My Block all cleaned and Bored out 60 over with all internals Balanced...
Not going to cover the Internals as there are plenty of recipes out there to follow and each there own...
My Brown Dog Engine mount kit However the Yellow did not work for me...
My FlowKooler High Volume Water pump
Good Old Timing Chain From HESCO that is for Degree-ing the Cam
A little Internal Bling for me here...
Getting ready to button it up
A few More Accessories Added and Painted up
That's all for now and More to come soon...
Would be interested in the pistons you used.  Looks like a bigger dish than stock - perhaps Hesco pistons for the supercharged engine?  I still need to figure out what I want to do for pistons in my stroker build.  Know I want to keep a stock cam shaft, just for reliability if nothing else.  Looks like Hesco roller rockers also?
  • 4 weeks later...
Done Very Soon maybe a week or two as I still need to assembly my Magnaflow Hot rod exhaust system and No immediate plans for the Dyno, just need to get my truck back up and running again...
Some More Progress on the Engine...
Transmission all cleaned up and Transgo Shift kit installed...
Decided to Modify my Rough Country Long arm kit Crossmember because I do not like having to practically remove the front axle anytime I need to service the trans...
Reconditioned the Head with Larger SS Valves (supercharging at a later date) and I think machine work for the valve springs otherwise nothing major as I eventually planning on an Aluminum head down the road so testing this setup first...
Was going to do a full port and polish but heard mixed reviews and since I have been eager to get my Truck back rolling I wasn't too worried about it right now...
OH and installed Harland Sharp Roller rockers
Time for a Few more updates...
Custom Fan Bracket from my Dual 10" Electric fans...
Ignore the Aluminum Rad as it was an EBay buy and was JUNK and only lasted me 2 weeks before it Died..
Then Opened up my Box of Exhaust Parts from MagnaFlow for my Custom Exhaust...
My Magnaflow XL Muffler and High Flow OBDII Cat...
Started Assembling my Collector Pipe...
New Beside the Old...
Completed Front Collector Pipe and welded in an 02 Bung in the cat...
Now onto the rest of the Exhaust and then Fire this Bad boy Up...
