a1awind Posted August 4, 2013 Share Posted August 4, 2013 For an oil additive....marvel mystery oil or lucas? Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted August 4, 2013 Share Posted August 4, 2013 Both are very good. I've used both. You can use MM in the gas too, similar to Seafoam. Link to comment Share on other sites More sharing options...
Eagle Posted August 4, 2013 Share Posted August 4, 2013 Depends on what you want to do. Marvel Mystery Oil is primarily a cleaning agent. It'll help keep the inside of your engine cleaner, but it doesn't make the oil any thicker, stickier, or "oilier." Lucas is a viscosity index improver. It does the same thing as STP -- it makes the oil thicker, stickier, and "oilier." Personally, if I want a thicker oil I buy a heavier weight of oil. I saw what running STP did to a friend's expensive racing engine once. It wasn't pretty. Link to comment Share on other sites More sharing options...
SW86 Posted August 4, 2013 Share Posted August 4, 2013 i throw a can of restore all in at every oil change (delo 400). it took out some of the ticking almost immediately. It did wonders in my old 97 maxima. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 5, 2013 Share Posted August 5, 2013 i throw a can of restore all in at every oil change (delo 400). it took out some of the ticking almost immediately. It did wonders in my old 97 maxima. That stuff works pretty good, doesn't it? Got rid of lifter tick in 2 different 4.0s for me. Link to comment Share on other sites More sharing options...
