Wiggilez Posted March 22, 2016 Author Share Posted March 22, 2016 So today I went to go pick up the missing link between my 86 MJ and my 90 XJ And while I was there I saw this it's a 91 aw4 2wd, it belonged to one of the clerks working and the electronic store, so we had a little chat about MJs Link to comment Share on other sites More sharing options...
Wiggilez Posted April 1, 2016 Author Share Posted April 1, 2016 I finished re-plugging my loom today, one done both done, I then cleaned up the wires that weren't used from the xj like the rear wiper and defrost, No pics of that. I'm done the wiring bit of the swap. it's something so small in size, but I feel so accomplished now that it's done :) Link to comment Share on other sites More sharing options...
HeavyHook Posted April 1, 2016 Share Posted April 1, 2016 What's your location now, Edmonton or Calgary, or a bit of both. I'm just outside of Chestermere. Link to comment Share on other sites More sharing options...
Wiggilez Posted April 1, 2016 Author Share Posted April 1, 2016 Primarily Edmonton, i do still past through calgary every now and then on my way down to Lethbridge. Link to comment Share on other sites More sharing options...
Wiggilez Posted April 2, 2016 Author Share Posted April 2, 2016 No pics, but I got my sending units swap clutch and brake pedals and the brake master cylinder. Link to comment Share on other sites More sharing options...
Megadan Posted April 2, 2016 Share Posted April 2, 2016 You're making good progress. Are those Deutsch connectors you used to combine the two together? Link to comment Share on other sites More sharing options...
Wiggilez Posted April 2, 2016 Author Share Posted April 2, 2016 You're making good progress. Are those Deutsch connectors you used to combine the two together? yup, and they're hella expensive. Link to comment Share on other sites More sharing options...
Megadan Posted April 2, 2016 Share Posted April 2, 2016 You're making good progress. Are those Deutsch connectors you used to combine the two together? yup, and they're hella expensive. They are, that's why I asked. Good investment though as they are probably the best connectors you can use. Link to comment Share on other sites More sharing options...
Wiggilez Posted April 3, 2016 Author Share Posted April 3, 2016 got busy today putting some of the wiring back in I had to rework some of the body to get the connect to fit, you can see the clean spot where it wouldn't fit litte bit of hammer time and it fits. also does anybody know what that black and white wire does or where it goes to. close up of the wire. also this wire, it's not the abs one or the one to cpu see you later space cowboy. Link to comment Share on other sites More sharing options...
Wiggilez Posted April 20, 2016 Author Share Posted April 20, 2016 took a small break from doing electrical to fix the gaping hole in my driver side floor. I started with a cardboard template then traced it on to sheet metal. not done yet, but this is where it's at then I got slightly distracted and took apart the abs unit to see what was inside the mercury switch I then called it a night after having a small ecological disaster by braking the mercury switch trying to remove it Link to comment Share on other sites More sharing options...
Wiggilez Posted July 4, 2016 Author Share Posted July 4, 2016 slight update while wanting for parts, got a replacement non abs brake booster and master cylinder, and a spare fuel sender. also another tool box also I started my swap to 4:10's but turns out tj d30's have caster adjustment on them so I ordered new bolt because the originals one's snapped when I was pulling the axle. I'm still trying to find some cheap 15r 5x5.5 rims to mount my tires on so that it will fit the new rear 9.25 Link to comment Share on other sites More sharing options...
Wiggilez Posted July 4, 2016 Author Share Posted July 4, 2016 started welding in a new driver side floor. not done yet but so far attempt #3 is looking alright also my first world problem of the day was getting my ponytail stuck in the adjustment knob of my welding helmet. :/ Link to comment Share on other sites More sharing options...
Wiggilez Posted August 2, 2016 Author Share Posted August 2, 2016 alright, so I finally got some stuff done one the jeep but laziness on fixing my computer and house sitting did imped my posting of it. first of picked up 5 rims with 31" for 80$ the tires have a little cracking in them, but the tread is almost new and for 80$ I can't complain. I also got my interior put back in. [/url] I haven't bothered with replacing the carpet yet, or headliner. also found this in an xj with 160xxxkm on the clock installing the 4:10 dana 30, also turns out 86 high pinion rotors don't fit 98 low pinion hubs. also in none comanche news finally got myself a decent air compressor alone with a few other new tools. compressor hose reel problem i hadn't bought enough hard line initially and had to go back for more. Link to comment Share on other sites More sharing options...
Wiggilez Posted August 8, 2016 Author Share Posted August 8, 2016 quick rant, got all the motor mount swapped from 2.8L to 4L but why the hell the the topside bolts 9/16th and the bottom 15mm, why couldn't they both be the same :/ preferably 15mm because canada. Link to comment Share on other sites More sharing options...
gogmorgo Posted August 9, 2016 Share Posted August 9, 2016 Because AMC engine made forever with SAE tooling and Jeep built with metric because metric is the future. Link to comment Share on other sites More sharing options...
Megadan Posted August 9, 2016 Share Posted August 9, 2016 Because America, ;) Link to comment Share on other sites More sharing options...
Wiggilez Posted August 10, 2016 Author Share Posted August 10, 2016 most of AMC's cars were being built in eastern Canada by the time my jeep was built... Link to comment Share on other sites More sharing options...
Megadan Posted August 11, 2016 Share Posted August 11, 2016 Yea, and American's still decided what parts went on it. The 80's is probably the worst era for mixed hardware on American vehicles. Link to comment Share on other sites More sharing options...
Wiggilez Posted August 12, 2016 Author Share Posted August 12, 2016 Yeah... on the bright side my corolla is really nice to work on other then the rust. Which i think is actually worse then on my MJ. Link to comment Share on other sites More sharing options...
Wiggilez Posted August 30, 2016 Author Share Posted August 30, 2016 so I spent some time working on my MJ today and I finally got my motor back in :D here are some pictures :)))))))))))) looks like I beat the firewall enough, because its fitting :) I reused the rubber mount from the donor XJ because they where still in got shape, not dried out or rotting unfortunately by the time I got everything in it was too dark for pictures, so those will come later. Link to comment Share on other sites More sharing options...
Megadan Posted August 30, 2016 Share Posted August 30, 2016 Looks good. Getting the big stuff installed goes a long way toward getting you excited about finishing a project. Looking forward to the first start Link to comment Share on other sites More sharing options...
