Tips Putting Pitman Arm Back On
So I can't get my pitman arm flush with my new (to me) steering box.
It won't hammer flush,and when putting the nut on to try and tighten it and force it up, I got the nut so tight it won't budge with a long pipe on my wrench and the pitman arm is still a ways away from being up where it should.  I had to use a puller to get the arm off the old box ... are they tapered or something?  Why can't I get it flush?!
.... anyone have any tips?
Did you align the grooves? There is  grove on the arm and shaft ti insure it will only go on in one position.
Yeah, they're lined up. So no one else has had problems with these? You guys' have just gone on real easy?
The ZJ box I got from a junkyard has a rubber collar (I wouldn't call it a boot) that fills that gap and covers the exposed splines. I've never seen that before -- none of my XJs or MJs has it.
