Echostrike Posted June 10, 2013 Share Posted June 10, 2013 All- I just got my new track bar from rock auto, and I went under the truck last night to scope out installation--and could not understand how it is removed at the axle side? The photo in the manual I have states there is a bolt with a nut on the end, but I have no idea how to get to the nut, as it looks blocked in by a welded backet. On this note, the bed proportioning valve in the back has a similar circumstance with a bolt going up into the frame, with an inaccesible nut attached to the end. All help appreciated. Link to comment Share on other sites More sharing options...
88whitemanche Posted June 10, 2013 Share Posted June 10, 2013 Funny that you mentioned that...mine didn't have a nut at the end. I just loosened the bolt and reinstall the bolt with no problems...some guys usually cut that cover when they drill a bigger hole for a bigger bolt and add a nut there Link to comment Share on other sites More sharing options...
jimoshel Posted June 10, 2013 Share Posted June 10, 2013 There is a tab hanging down from the mount. The nut is welded to it. You don't need a wrench. Link to comment Share on other sites More sharing options...
Echostrike Posted June 10, 2013 Author Share Posted June 10, 2013 There is a tab hanging down from the mount. The nut is welded to it. You don't need a wrench. Yeah I've seen this tab on some of "bleepinjeep"'s videos, but I don't see it on mine...could not be looking hard enough. Hopefully I can just remove the bolt, without bothering about the nut. Anyone take off there height valve in the back? theres two bolts vertically into the underside of the frame, and one has a nut--how'd you remove it? ohhhhh Jeep! Link to comment Share on other sites More sharing options...
deziped1 Posted June 10, 2013 Share Posted June 10, 2013 If the track rod bolt has a nut on it, wedge a large screw driver in there so the nut won't turn and back the bolt out. Link to comment Share on other sites More sharing options...
jimoshel Posted June 10, 2013 Share Posted June 10, 2013 I just checked. The '86 does not have any way to access the rear nut. The '87 up has the nut-tab thing. Just try to remove the bolt. If it turns without coming out you're screwed. You will have to cut a hole in the brace so you can reach the nut with a wrench. 1986 track bar mount D*mn PB! Link to comment Share on other sites More sharing options...
Echostrike Posted June 10, 2013 Author Share Posted June 10, 2013 I just checked. The '86 does not have any way to access the rear nut. The '87 up has the nut-tab thing. Just try to remove the bolt. If it turns without coming out you're screwed. You will have to cut a hole in the brace so you can reach the nut with a wrench. 1986 track bar mount D*mn PB! Man! not what I wanted to hear, but figured. Ha, I love in the FSM, it is just like: oh you know, just remove the bolt and nut..... not to mention the giant bracket around it! Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted June 11, 2013 Share Posted June 11, 2013 Jimoshel, On my 90 i replaced the original "tabbed" nut with a standard, bad move on my part because it does make it much more difficult to take the bolt in and out, but it is still possible to get a open ended wrench in there to hold the nut still. You just have to spin the bolt until it is in just the right position. I would just give it a shot before chopping up the bracket. Link to comment Share on other sites More sharing options...
jimoshel Posted June 11, 2013 Share Posted June 11, 2013 I was referring to the '86 mount. It does NOT have an opening to fit a wrench, or anything else in. Link to comment Share on other sites More sharing options...
jimoshel Posted June 11, 2013 Share Posted June 11, 2013 A pic of the '86 track bar mount. No hole. Link to comment Share on other sites More sharing options...
jimoshel Posted June 11, 2013 Share Posted June 11, 2013 I gave up completely on PB after trying for two days to post the above pic. I just tried imgur as per a suggestion by gogmorgo. Seems to be working. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted June 12, 2013 Share Posted June 12, 2013 A pic of the '86 track bar mount. No hole. Seriously, W.T.F How in the world did they even mount the track bar then??? :doh: Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 12, 2013 Share Posted June 12, 2013 Weldnut. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted June 12, 2013 Share Posted June 12, 2013 What i figured. Probably welded the nut to the bracket then welded the bracket to the axle tube. Link to comment Share on other sites More sharing options...
Lee21490 Posted June 12, 2013 Share Posted June 12, 2013 My first comanche must have had the bolt break off, Because there was a huge gaping torch hole where the Nut used to be, Whoever did it had the ugliest torch skills i've ever seen. But it got the job done, So ohwell. Link to comment Share on other sites More sharing options...
jimoshel Posted June 12, 2013 Share Posted June 12, 2013 For the information of any one wanting to fix the track bar nut problem, This is what you want. Any JY should have one for a couple bucks, or for the masochists that want to make their own. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 12, 2013 Share Posted June 12, 2013 From the dealer: 34202463, Nut, Retainer, $2.8034202640, Bolt, $7.14 Link to comment Share on other sites More sharing options...
jimoshel Posted June 12, 2013 Share Posted June 12, 2013 Not used to dealing with dealers. Almost forgot they exist. :yes: Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 13, 2013 Share Posted June 13, 2013 The post was for the benefit of the rust belt guys. It's tough to find a used bolt and nut in semi usable condition in them thar parts. Link to comment Share on other sites More sharing options...
jimoshel Posted June 16, 2013 Share Posted June 16, 2013 Was out removing front end parts from a '86XJ. Broke a nut loose with a 1/2 inch ratchet and then unscrewed the nut off with my fingers. While unscrewing it the thought hit me. Bet the guys, and gals, in the rust belt can't do this. 'nuff said. While under there I noticed there is a narrow gap above the bottom of the torque mounting bracket. If some one was unfortunate to have the weldnut come loose on them, there is enough room to slide a screw driver or chisel, something wedge shaped thru this slot and jamb it between the nut and bottom of the mount. By cutting the slot out enough a guy could slip a box end wrench in there and hold the nut. Would also work when re-installing the bolt. This slot is on the inside side of the mount. Get under the Jeep and look up. You can see it. Link to comment Share on other sites More sharing options...
mvusse Posted June 16, 2013 Share Posted June 16, 2013 It is difficult to reach, but it is possible to get in there with an open end wrench. Link to comment Share on other sites More sharing options...
Echostrike Posted June 20, 2013 Author Share Posted June 20, 2013 So Update: Got the track bar off, the bolt was indeed welded in place like noted. Thanks. I really thought it would be more difficult to remove, but it came out with little fuss and a BFH. Now, the steering stabilizer....thats a different story. I cannot get the tie rod end out for the life of me, I actually had to give up on it last night. Thing is ridiculous. Link to comment Share on other sites More sharing options...
