What Are These?
Found these things in the new truck. I seem to recall seeing the plastic shield before on one of my old rigs, I want to think it goes on the front of the gas tank? The other thing I don't have the slightest clue.
So it is a steering column brace but it goes on the right side. Anyone able to tell me where about the other end goes? I can't locate the bolt anywhere, could be missing I suppose. Test fitting it the only place that seems to work is down by the gas pedal on one of the bolts that hold that bracket. Is that correct?
Both bars go on the left bolt
This is correct. One bar bolts at a 90* angle to the steering column, just above the hood release handle. The other bar attachs to the left of the fuse box, it uses one of the parking brake mounting bracket bolts.
