87sparTruck Posted May 28, 2013 Share Posted May 28, 2013 I have 4 door cherokee buckets at the moment and 5' 10". Link to comment Share on other sites More sharing options...
KYMJ Posted May 28, 2013 Share Posted May 28, 2013 Just buy Comanche brackets. I have Cherokee buckets on Comanche brackets. Link to comment Share on other sites More sharing options...
87Warrior Posted May 28, 2013 Share Posted May 28, 2013 Yes, if they come with the floor mount/bracket. Link to comment Share on other sites More sharing options...
87sparTruck Posted May 28, 2013 Author Share Posted May 28, 2013 They come with ripped seats and the comanche brackets. Link to comment Share on other sites More sharing options...
Pete M Posted May 28, 2013 Share Posted May 28, 2013 there's no way I'd pay that much for flawed seats just to get the mounts. especially since an MJ bench has the same floor mounts as the MJ buckets. perfect seats, yes. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted May 28, 2013 Share Posted May 28, 2013 I can get 4-door XJ buckets all day at the JY for $25 each. The ones in my MJ are clean XJ 2 door seats...and I mounted them on my bench seat brackets (as Pete said...same bracket)...so $150, for ripped 4 door buckets that don't fold forward, not for my money...BUT, I'm sure there is someone out there who doesn't know how to do the swapping and has more money than brai...er...I mean time. Link to comment Share on other sites More sharing options...
87sparTruck Posted May 28, 2013 Author Share Posted May 28, 2013 My bench has the curved brackets and they are rotted. I can probably make due with the cherokee buckets/brackets or fab up something. I have some javelin seats that might work with a little ingenuity. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted May 28, 2013 Share Posted May 28, 2013 You need MJ brackets because of the topography of the floor...which is completely different than the topography of the XJ floor...regardless of the seats. With MJ brackets you could very well adapt just about any seat that would fit with...like you said, some ingenuity, and flat or angle stock and some nuts and bolts. Without the brackets, nothing will sit flat at the top of the bracket. Link to comment Share on other sites More sharing options...
Eagle Posted May 28, 2013 Share Posted May 28, 2013 The disadvantage to 4-door XJ seats is that they don't fold forward. MJ seats, and 2-door XJ seats, do fold forward. You can always swap the upholstery from the XJ seats onto the MJ frames -- you'll just have to cut a small slit for the lever that releases the backs to fold forward. Is that worth $150? I dunno -- that's a very subjective call, and while it might be a good deal for one person, it might not be a good deal for someone else. Link to comment Share on other sites More sharing options...
Keyav8r Posted May 29, 2013 Share Posted May 29, 2013 Invest $300 to $400 in a MIG welder (you want one, anyway) and fab some brackets to mount almost any seats you want into your MJ. It may take a couple of tries to get it exactly like you want it. If you already have 4 door XJ buckets, you can use them until you find some two door buckets, either MJ/XJ or something else. Link to comment Share on other sites More sharing options...
87sparTruck Posted May 29, 2013 Author Share Posted May 29, 2013 That's why I mentioned javelin seats the fold forward like the 2 door xj's cuz the javelin is a 2 door with a back seat. And I'm all set with the welder. lol Link to comment Share on other sites More sharing options...
