ghetdjc320 Posted May 21, 2021 Share Posted May 21, 2021 1 hour ago, EagleEar said: I found front axle, please advise if its Dana 30 . There is nothing for front with gearing 4.10 more common are 3.73 and 3.55. According to post above I should have 4.10 on the rear , will it works ? Or something like that JEEP XJ 97-01 4.0 gearing 3.55 Looks like a Dana 30. The bottom picture looks like it is from a grand Cherokee since it has CV joints instead of U joints. Link to comment Share on other sites More sharing options...
EagleEar Posted June 4, 2021 Share Posted June 4, 2021 Please advise if I'm wrong. What is hidden after removing that part marked on red ? Is there a chance to mount transfer case instead it ? Link to comment Share on other sites More sharing options...
scaleless Posted June 4, 2021 Share Posted June 4, 2021 4 hours ago, EagleEar said: Is there a chance to mount transfer case instead it ? No. A 4x4 transmission has a different tailcone and a different output shaft. Link to comment Share on other sites More sharing options...
Pete M Posted June 6, 2021 Share Posted June 6, 2021 On 5/19/2021 at 7:12 AM, ghetdjc320 said: I’m not sure what engine you currently have but the 4.0 and 2.5 DON'T share the same engine to transmission bolt pattern. The ax5 and the ba10/5 are the least desirable options but I understand sometimes you have to just use what you can get. Are you trying to do a 4wd conversion? you missed a word. Link to comment Share on other sites More sharing options...
Pete M Posted June 6, 2021 Share Posted June 6, 2021 if you can, I would seek out a whole 1990+ cherokee to do the swap. but I don't know how plentiful those would be around you. Link to comment Share on other sites More sharing options...
