zackcj7 Posted April 10, 2013 Share Posted April 10, 2013 Can someone tell me where the vacuum line attached to B in the drawing below goes? Mine is just hanging. The EGR Solenoid is right beside the ballast resistor next to the airbox. Link to comment Share on other sites More sharing options...
Geonovast Posted April 10, 2013 Share Posted April 10, 2013 There should be a round, flatish valve on the driver's side of the intake manifold. That's the actual EGR valve, which should be connected to point B. Link to comment Share on other sites More sharing options...
zackcj7 Posted April 10, 2013 Author Share Posted April 10, 2013 There should be a round, flatish valve on the driver's side of the intake manifold. That's the actual EGR valve, which should be connected to point B. Man that was fast! Thanks, i'll look for it when I get home. Link to comment Share on other sites More sharing options...
hitman72 Posted April 10, 2013 Share Posted April 10, 2013 sorry to be a little off topic but, is there a good write up on how to make sure your EGR system is working properly. Cause I don't really know how it works (i get the idea) and have no idea if it is working properly. thanks Link to comment Share on other sites More sharing options...
64 Cheyenne Posted April 10, 2013 Share Posted April 10, 2013 sorry to be a little off topic but, is there a good write up on how to make sure your EGR system is working properly. Cause I don't really know how it works (i get the idea) and have no idea if it is working properly. thanks The first one is a home page of some excellent Jeep stuff, and the second is specifically Renix. Answers to your EGR questions are here. http://www.lunghd.com/On_Site_Tech.htm http://www.lunghd.com/Tech_Articles/Engine/Basic_Sensors_Diagnostics.htm Link to comment Share on other sites More sharing options...
hitman72 Posted April 10, 2013 Share Posted April 10, 2013 sorry to be a little off topic but, is there a good write up on how to make sure your EGR system is working properly. Cause I don't really know how it works (i get the idea) and have no idea if it is working properly. thanks The first one is a home page of some excellent Jeep stuff, and the second is specifically Renix. Answers to your EGR questions are here. http://www.lunghd.com/On_Site_Tech.htm http://www.lunghd.com/Tech_Articles/Engine/Basic_Sensors_Diagnostics.htm Thanks you, will give it a read later. Also found some in the DIY write up section. Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 10, 2013 Share Posted April 10, 2013 Just to beat a dead horse here it is from the FSM Link to comment Share on other sites More sharing options...
zackcj7 Posted April 11, 2013 Author Share Posted April 11, 2013 Thanks guys. Got it connected back where it goes last night. Link to comment Share on other sites More sharing options...
hitman72 Posted April 12, 2013 Share Posted April 12, 2013 Wait a second, I am not looking at the truck at the moment but i would swear that I have a hose coming from the manifold to air box (looks to be a metal corrugated pipe, like a small dryer vent pipe) and there is a valve mounted in the side of the air box. Am i completely wrong, is this another system i am looking at? Link to comment Share on other sites More sharing options...
Geonovast Posted April 12, 2013 Share Posted April 12, 2013 That vent dryer hose thing doesn't actually do much. It's just to help warm up air before it gets to the intake, it doesn't route any exhaust. If you pull it off the manifold, you'll see that there's no hole. The EGR uses an actual pipe that's threaded into both manifolds. Link to comment Share on other sites More sharing options...
hitman72 Posted April 12, 2013 Share Posted April 12, 2013 Roger thanks. So it can be removed? I guess I would need a new air box..... Link to comment Share on other sites More sharing options...
Geonovast Posted April 12, 2013 Share Posted April 12, 2013 Yes, it can be removed. No, you don't need a new air box. Why would you? Link to comment Share on other sites More sharing options...
hitman72 Posted April 13, 2013 Share Posted April 13, 2013 I when I was thinking about it in my head I thought there was a hole where it came into the box. But then once you said that I realized it would just mean more air openings in the box....... Long story short a brain fart.... haha Link to comment Share on other sites More sharing options...
Geonovast Posted April 13, 2013 Share Posted April 13, 2013 Yup, doesn't matter since it's below the filter. :thumbsup: Link to comment Share on other sites More sharing options...
