Rubicon Shocks On An Mj?
Has anyone found a use for 2012-2013 Jeep Rubicon shocks take-offs on their lifted or un-lifted MJs?
I see them on CL, essentially brand new for like $50, for all four corners!
Front uncompressed/compressed 22.75/15 inches.
Rear 23.25/11.5 inches
Just curious because they have correct ends for front/back and are probably decent grade of shocks that are spec'd for an OEM Rubi
I have regular JK shocks on my MJ. They were about 1 inch longer total than the OEM MJ shocks. That worked out fine for me going from 2wd to 4wd, though I think I could have used a little more length in the back. But they ride good for being free take offs and I have no complaints with them otherwise. As was stated the bar pin for the rear top was removed and installed in the front lower to make them work.
I just installed a set in the front of my comanche with 2 inch lift and they do seem a tad short.  I also installed JKS bar pin eliminator kit which adds a bit of length.  I ran these this way on an 89 Cherokee I had with 3 inch lift and never has a problem.
