Rear Brake Adjustment
What is this tool you speak of?
When I adjusted mine I just used my fingers then test fit the drum till it was just able to go on, then I let the self adjuster do the rest... I think I read to drive forward then press the brake hard, then reverse and press the brake hard, then repeat 3 times...
The next stop sign that grandma blows through and you slam the brakes will finish the adjusting process lol
edit
When I adjusted mine I just used my fingers then test fit the drum till it was just able to go on, then I let the self adjuster do the rest... I think I read to forward then press the brake hard, then reverse and press the brake hard, then repeat 3 times...
Nothing works like a proper manual adjustment with the drums and wheels in place.
Don't knock it. It works.
cruiser54, AWESOME description! Thank you so much. When I looked at the replys, I was almost expecting "up, or down". I tightened them, and the e-brake still doesn't hold. I'm going to try it again. Thanks!
my e-brakes are not working as well.... mostly because the cable is stuck in the apply brake position and the little cross bars apparently had to be removed...  I discovered this Saturday when i tried to fix my e-brakes...  Do you know if you have all the hardware? no amount of adjusting is going to help the e-brake unless you have all the parts.
