mpace6a Posted February 27, 2013 Share Posted February 27, 2013 So the intake on my 2.8 cracked..and i can get it repaired cheap, but i have a fuel injected intake, and was wondering if anyone knew of a carb that would bolt on to the fuel injection intake? Next question, does anyone know what this ground is for? Its back of the cab, passenger side. And lastly, whats this pink wire? Driver side B pillar Link to comment Share on other sites More sharing options...
86MJV6 Posted February 27, 2013 Share Posted February 27, 2013 I have the same unused pink wire, I believe one of the other posts stated it was for the dome light. I don have a dome light, just b-billar lights so its an unused connector in mine. Not sure about the ground. Link to comment Share on other sites More sharing options...
jimoshel Posted February 28, 2013 Share Posted February 28, 2013 Ground looks like it may have been for a aftermarket Amplifier. Not OEM. Link to comment Share on other sites More sharing options...
jeepsouth Posted February 28, 2013 Share Posted February 28, 2013 Po prob. had an amp grounded with that. You beat me to it Jim. Link to comment Share on other sites More sharing options...
Geonovast Posted February 28, 2013 Share Posted February 28, 2013 I believe the pink wire is for the factory cargo light, not a dome light. Not many had the cargo light, but I believe they were all wired for it. Link to comment Share on other sites More sharing options...
gogmorgo Posted February 28, 2013 Share Posted February 28, 2013 This begs the question, why do you want to go to a carb? Link to comment Share on other sites More sharing options...
Geonovast Posted February 28, 2013 Share Posted February 28, 2013 The 2.8's already carbed, I'm betting he just doesn't want to do the FI conversion. Link to comment Share on other sites More sharing options...
gogmorgo Posted February 28, 2013 Share Posted February 28, 2013 mm... missed that. Read 2.5... :doh: Link to comment Share on other sites More sharing options...
mpace6a Posted February 28, 2013 Author Share Posted February 28, 2013 The 2.8's already carbed, I'm betting he just doesn't want to do the FI conversion. Exactly. My intake cracked, and got to looking at the intake from the donor engine from an s10, and wondered if there was a carb that would work, because the OE carb is far to complicated and i want to do away with as much emissions and vacuum as possible, to hopefully get as much life as possible out of the 2.8. I don't want to buy a different intake specifically for a carb because they cost more than what i've got into this engine, and i can't justify spending money on a performance intake on a crap engine, but i may look into having an adapter made for this intake to mount a motorcraft 2 barrel i have off an old dodge 318 Link to comment Share on other sites More sharing options...
jimoshel Posted February 28, 2013 Share Posted February 28, 2013 You could go to a after market carb. They're big bucks tho. S10's are so common you should be able to find what you need in any JY. I believe '85 was the last year for the S10 carb. May have been '86. Personally I believe you would be better off swapping to a TBI. Much simpler than a carb and improved performance. If you can't find what you need at a local JY, drop me a line. I may be able to help. Link to comment Share on other sites More sharing options...
mpace6a Posted March 1, 2013 Author Share Posted March 1, 2013 my biggest issue is i don't want to put any more money into it than is necessary, and at the same time want to clean up the engine bay. i havr the motorcraft carb, but the s10 tbi intake would need to be bored out to work with the carb...hopefully my oe intake can be repaired.... Link to comment Share on other sites More sharing options...
