86MJV6
    Mountain Home, ID
636 profile views
86MJV6's Achievements
  1. I have a black ash tray if you are interested.....let me know and I can pm a pic.
  2. 86MJV6
    Grey Interior
    I have two grey window cranks...the knobs are different tho...one is grey and the other is clear....I will try and pm some pics if interested.
  3. Steve, I had the same fitment issues...i sent you an email. Thanks Matt
  4. I ordered one today. Appreciate everyone's assistance and info. Thank you.
  5. Thanks, I appreciate the info. I don't have access to a signal generator. I think I can get by using an o-scope or the hz function on the dvm. Sounds like I could have used the one from a 2.5.
  6. I Believe so, don't have anything to back that up tho. I assumed 90 and older 6 would have been compatible. And the 4 would not have been accurate on my 2.8. I'll keep researching it.
  7. 86MJV6
    Newbie
    Nice find, and can appreciate keeping it stock!
  8. Thanks, doesn't seem like it will work and Appreciate the offer...
  9. Does it have an adjustment on the back, either a resistor or potentiometer of some sort?
  10. Thanks, so far all I have seen have been 91 and newer. Didn't think about the mileage, will do that when I find one. I think it's two Sending units that need swapped from what I read, the oil and temp.
  11. 86MJV6
    Idaho
    In Mountain Home, joined a little over a month ago.
  12. WTB a cluster with tach and gauges (no idiot lights) for 1986 Comanche X, 2.8 V6.
  13. I have the same unused pink wire, I believe one of the other posts stated it was for the dome light. I don have a dome light, just b-billar lights so its an unused connector in mine. Not sure about the ground.
  14. Steve, Any update available on the headliner? Thanks
  15. 86MJV6
    Need This Stuff
    How many door pins? For the hinge?
