Zenobian_84 Posted February 6, 2013 Posted February 6, 2013 Going to re-do the door panels for the 2nd time (sometime in the very near future) and was looking for some inspiration. Here's what I'm starting with; Going back to the original speaker size up front (5 1/4) and matching 4x6's for the back. Don't know if the PO has butchered the wiring for the rear speakers, but I wouldn't be surprised if he had... :thwak: Depending on how well the Gorilla glue worked on holding the top "mounting plate" to the re-made door vinyl panel is going to determine whether or not I keep the "Old Man Pants" blue trim. I'm just going to assume that the material is probably going to be non-recoverable. - - - Seeing as how I'll have to remove most of the interior pieces to install the rear speakers, I figure I could color them differently to get a different look out of the truck. I was thinking about possibly doing a "Tan" or "Black" color; but I really do like the OMP color. It just screams "AMC". 8) Anyone got any suggestions on a new color scheme? I could always re-paint the dash, I suppose; I do have to fix some buggered up things behind it soon anyway. :dunno: AMC Blue is a hard color to mix and match with. A shame I don't have plain black or something.
neohic Posted February 6, 2013 Posted February 6, 2013 What you've got is unique. I only wish I had a truck that would match the personality of a blue or red interior! Yes, there's just something so stunning about the ever elusive black interior, and I'll even admit that I'll be putting a black interior into one of my trucks soon enough, but that blue... :bowdown:
Biotex Posted February 6, 2013 Posted February 6, 2013 Where did you get your dash pad? I'm needing one...
Guest Posted February 6, 2013 Posted February 6, 2013 What you've got is unique. I only wish I had a truck that would match the personality of a blue or red interior! Yes, there's just something so stunning about the ever elusive black interior, and I'll even admit that I'll be putting a black interior into one of my trucks soon enough, but that blue... :bowdown: Thanks Ben. :cheers: I will admit that the interior goes very well with the exterior paint scheme. Not to mention I've only run across 1 other Jeep with the OMP colored interior (88 Cherokee Laredo?) Just throwing around options right now. If I can successfully remove the faux-leather from the backing board, I'll probably continue along with the blue interior. :yes: Where did you get your dash pad? I'm needing one... Lucked out at the P&P and found one (along with the glove box door pad, which I don't use) in an 86 Cherokee Pioneer. Seems to be mostly an AMC-era item; I have yet to run across any Chrysler XJ with a dash pad.
87MJTIM Posted February 7, 2013 Posted February 7, 2013 Where did you get the panel boards? The ones on mine are suffering from water damage. Probably from a leaking side vent window.
Guest Posted February 9, 2013 Posted February 9, 2013 Where did you get the panel boards? The ones on mine are suffering from water damage. Probably from a leaking side vent window. Used the original backing board as a reference; went to Home Depot and picked up a 1/8" hardwood board to use as replacement. Layed the old on the new and drilled the correct size holes / cut out the right size board. Done right, this setup should last a long time. :thumbsup:
