Jaime Posted January 12, 2013 Share Posted January 12, 2013 Will the instrument panel off a automatic cherokee work on my 5 speed MJ? Link to comment Share on other sites More sharing options...
jimoshel Posted January 12, 2013 Share Posted January 12, 2013 Yes. Link to comment Share on other sites More sharing options...
relyt120 Posted January 12, 2013 Share Posted January 12, 2013 As long as it is the same type, renix or not etc... Link to comment Share on other sites More sharing options...
Jaime Posted January 13, 2013 Author Share Posted January 13, 2013 Thanks for the quick response. I was at the junk yard and had my son post this for me. I was able to snag the instrument cluster and a rear view mirror for $15.00 Is there any way to move the mileage back? It shows about 100,000 miles more than mine. Thanks again Link to comment Share on other sites More sharing options...
ParadiseMJ Posted January 13, 2013 Share Posted January 13, 2013 If the old cluster has idiot lights instead of gauges, you'll need new sensor/senders for temp and oil pressure. If you're just swapping a gauge cluster for a gauge cluster, it's plug n' play. As for the second question, drive in reverse. Actually you SHOULD certify the "not actual mileage" claim with the DMV in case you ever sell it. Link to comment Share on other sites More sharing options...
Jaime Posted January 13, 2013 Author Share Posted January 13, 2013 I never thought about that. This gives me more reason to ask if it would hurt the new cluster if I put a drill on the pigtail coming out of the speedometer and ran it backwards until I hit the milage on my original cluster. Link to comment Share on other sites More sharing options...
relyt120 Posted January 13, 2013 Share Posted January 13, 2013 There is a way to do it but I don't know it. Something to do with actually moving the numbers....look in the DIY section Link to comment Share on other sites More sharing options...
Exgrayxj Posted January 20, 2013 Share Posted January 20, 2013 I never thought about that. This gives me more reason to ask if it would hurt the new cluster if I put a drill on the pigtail coming out of the speedometer and ran it backwards until I hit the milage on my original cluster. Doing it that way, it will take the rest of your life, it will only take off miles as fast as they went on, a drill won't spin very fast. Face it, even at 100 mph, it will take a while to unroll 100k. It isn't very hard to do, to reset one of the mechanical ones, the newer ones are beyond me. Take a little time, pay attention to the "legs" that align the numbers, once the "number roll" whatever the official name is, is out just hold things in place, turn the digits to where you want. I did it on mine, set the replacement speedo to the same as my original, probably took maybe an hour, or less. Just pay attention how it rests in there! Link to comment Share on other sites More sharing options...
fiatslug87 Posted January 21, 2013 Share Posted January 21, 2013 This is from the '90 FSM, it's in the SJ section but it worked for my MJ. Link to comment Share on other sites More sharing options...
Jaime Posted January 21, 2013 Author Share Posted January 21, 2013 Thank you. I reset the new odometer to my original milage. Not hard at all. Thanks again. Link to comment Share on other sites More sharing options...
