cgmrdc Posted December 16, 2012 Posted December 16, 2012 So, a small introduction here, I started off in an XJ and then built a very capable, DD TJ while in school, click the link below for the build thread. Traded it with plans of building a buggy, but a year later and a big career move i still hadnt started the buggy build and was tired of not wheeling so i picked this up for 500 bucks. TJ Build http://www.jeepforum...ge-fund-878243/ 88 MJ 4Cyl, 5 speed, 2 wd Basically everything I have collected for the buggy will be going into this build. 350 on propane, sm465, dana 300. Currie Rock Jock 60, 5.38s, 35s spline inner and outer alloys, drive flanges, detroit. Full hydro Shaved 14 bolt, 5.38s, detroit, disc brakes. Currie antirock Rear Sway Bar 16 inch FOA coilovers 4 in FOA air bumps 39.5 TSLs 105-107 in WB Dual Wilwood master cylinders and cutting brake. Mastercraft seats Warn HS9500 winch 4 links front and rear The plan for the MJ is do 2x6 rocker/boat sides, internal cage, Rear in going to be cut off behind the cab and tubed out, Front grill is going to be narrowed, tube fenders and engine cage with the winch behind the grill and the radiator in the back. Interior is going to be stripped and have custom dash... Hopefully done by March. pics
cgmrdc Posted December 16, 2012 Author Posted December 16, 2012 makin some progress strippin stuff shed cleaned up again jeep rolled in with all major components removed literally zero droop... no longer an issue... sage is ready to go wheelin... and just can't stop cutting!
cgmrdc Posted December 16, 2012 Author Posted December 16, 2012 frame prep a sharp wood chisel works really well to scrape the majority of the undercoating off, for future reference. then i used aircraft stripper to remove the rest of the paint and such when i cut the inner fenders out i left the finch seem where it was spot welded to the frame, but I'm wanting to box the whole front frame section in sooo... then folder it over with a hammer and welded it back together the last 12in or so were left unstripped and welded because one the motor goes in ill be cutting it off and tubing the rest to clear the 60
cgmrdc Posted December 16, 2012 Author Posted December 16, 2012 Currie 60 14 Bolt 39.5s FOA air bumps
mountainman Posted December 16, 2012 Posted December 16, 2012 Gonna be a SICK rig when finished. The only whine i have is, i wish you could have come acrossed a more beat rig. That was WAY too nice a truck to destroy. BUT... its better than it being donated by some jackass and end up in a crusher. :) can't wait to see it all done.
cgmrdc Posted December 16, 2012 Author Posted December 16, 2012 It was impounded by the Kansas Highway patrol for being left on the side of the road too long and the guy couldnt pay the impound fees, threw a rod, passed thru half a dozen hands and had a jacked up title. would have been a good rig to build a DD out of but i wanted a clean slate to build and already have a truck. so as much as it does suck to cut up, its been really nice to work with. ive got some ideas to protect most of the sheet metal, its gonna be wheeled hard but i like my rigs to stay clean.
cgmrdc Posted December 16, 2012 Author Posted December 16, 2012 Here is some examples of work ive done in the past, the first one is my old tj, the rest are rigs ive built for friends My TJ Friends TJ Two other friend's XJs And another XJ
cgmrdc Posted December 16, 2012 Author Posted December 16, 2012 finally feel like I'm making steps forward instead of just taking things apart folded all the pinch seams and rewelded them Cut off the "gussets" started on the templates for the frame plates, doing 3/16 on bottom and inside, 12 ga on the outside got one section cut out and tacked up
SW86 Posted December 16, 2012 Posted December 16, 2012 i know where that is :rock on: really does suck about cutting up a such a clean MJ but i held off to check out your work before i said anything. i mean as long as your doing it justice with the build (seems you are) hack that mother @#$%er up! :D
cgmrdc Posted December 16, 2012 Author Posted December 16, 2012 yeah, smorr is an awesome place to wheel. i knew i was gonna catch some flack on this board for cutting as much off as i have, but i swear I'm not just some hack and stab builder, everything that ive cut, has had a reason, and needed to be out of the way so i can turn this into what ive dreamed it to be.
johnny quest Posted December 16, 2012 Posted December 16, 2012 very nice build. i got the same crap from a few people when i started my build. but in the end, its your comanche, so do what you want with it. ill def be keeping up on this build; ive got my 60/14 in, but still have some work before it hits the dirt
87Warrior Posted December 16, 2012 Posted December 16, 2012 Holy smokes. I can hardly believe that truck was in KS. It's far too rust free! Looks like you are well on your way with a solid plan set forth. I look forward to watching this truck some to fruition. Sooo....when you cut those rust free cab corners out for the 2x6 rocker, would you sell 'em? :)
cgmrdc Posted December 16, 2012 Author Posted December 16, 2012 Holy smokes. I can hardly believe that truck was in KS. It's far too rust free! Looks like you are well on your way with a solid plan set forth. I look forward to watching this truck some to fruition. Sooo....when you cut those rust free cab corners out for the 2x6 rocker, would you sell 'em? :) i was pleasantly surprised with its condition... i was finding alot here in texas in the 1000$ range with more rust that this one. i wasnt even mad about the little bit in the drivers floor when i peeled the carpet back. i could probably manage to keep em in useable shape when i cut em out if you are interested. cutting all the way up to the first body line so there will be a lot of useable sheetmetal left. prob won't be till after new years, gotta go to kc to see the family for christmas and such, i make regular trips up there so we could prob work out a way to not have to ship em
cgmrdc Posted December 17, 2012 Author Posted December 17, 2012 Cut the rear frame off yesterday And before anyone throws a fit about this next picture, its only temporary, i can lift the jeep myself, the 4x4 is just a secondary support, its also safety chained to the ceiling rafters... i got the rest of the bottom plates cut out and the middle pieces tacked up
cgmrdc Posted January 24, 2013 Author Posted January 24, 2013 So, not much of an update, but its something for now. I figured Id be back at this by now, but the day i got home from the holidays we started a huge project at work and ive been working 10-12 hour days every day since the 9th. But here are a few more parts ive collected for the MJ 77 4 bolt main 350, itll be freshened up a little, new gaskets, ive got a set 64 CC heads that have been rebuilt to help the CR for the propane on stock pistons, dual plane aluminum intake manifold and lunati cam for it too wake it up a little. also have a serp belt set up for it and need to get a msd dist and ignition box. itll be a mild 350 by most standards, but itll get me on the trail while i build the 383 i want. Picked up a set of 12 bolt H1s with rubber inserts and a radiator for free! brand new, was for a gasser superduty a buddy used to have. should make a good candidate for a rear mounted rad. Got some dimple dies from TMR Cutting brake from off here And kind of related, picking this up on saturday, i have a 26 ft gooseneck that i bought in college for hauling two jeeps, its too long to justify hauling just the one jeep but i got a stupid awesome deal on it so would like to hold on to it. i couldnt buy a 16 ft bumper pull for what i paid for this gooseneck... gonna throw it on the front and help keep the lady happy when winter wheeling. project wraps up on the 28th, then ill be gone for a couple days wheelin with some friends. but when i get back ill pick up the rest of the material i need and should start coming together pretty quick.
North4x4 Posted January 27, 2013 Posted January 27, 2013 This thing is going to be sick, can't wait to see this come together. I'm definitely going to be watching this thread. Good luck with the project.
cgmrdc Posted February 11, 2013 Author Posted February 11, 2013 Another small update, i swear I'm gonna get some decent progress done one of these days, at least this post will have a little tech in it... but first, got the camper set up and took it to SMORR Froze Over. all i can say is WAY better than tent camping, especially in the bitter cold This is the trailer i started with Finished up about 2 am the morning i was supposed to leave. The outside is a little rough but the inside is in really good shape for 1971... Stove, over, fridge and heater all work! Just the right size for a jeep on the back (lilnickt's xj)
cgmrdc Posted February 11, 2013 Author Posted February 11, 2013 Some wheelin pics Nick Matt Me and the GF in my buddies "Spareokee", XJ we built one weekend out of spare parts for an extra rig while he puts tons under his TJ
cgmrdc Posted February 11, 2013 Author Posted February 11, 2013 and back to the MJ Picked up some LED fog lights, 20 bucks, don't know where I'm gonna use em yet, but oh well... maxxima 6.5x4s got some more plate for the frame, 90 ft of DOM to start the cage, 2x6 box and 1.5 spare for the boatsides so the side stiffeners are a little more difficult to make templates for, obviously you can trace out the lines on cardboard, so i drew lines on the frame every two inches and measured the cross section then i transferred that to the cardboard cut it out and trimmed a couple small spots the best part is this template works for the inner and outer frame rails, so i traced it on the steel and cut it out, cleaned em up and tacked em on Got some friends from back home coming down at the end of the month to help rebuild the motor and get it set in place so should be quite a bit going on from now till then... as long as work cooperates...
Dirteatr717 Posted February 11, 2013 Posted February 11, 2013 Sweet build, I've been watching it on pirate and didn't notice it over here, not gunna lie I drooled a little at that parts list! Can't wait to see some more updates :wrench:
89Comanche4x4 Posted February 16, 2013 Posted February 16, 2013 epic. how do you get the camper on and off the trailer, haha
cgmrdc Posted February 24, 2013 Author Posted February 24, 2013 epic. how do you get the camper on and off the trailer, haha The camper stays on the trailer... its the dedicated toy hauler. i have another 20 ft goose and 16 ft bumper pull that i use to haul other stuff. getting it from one trailer to the other was a chore lemme tell ya... used a bunch of pipe and 2x4s to roll it from one to the other. ive got the jack poles for it but a couple of the corners were weakened from storm damage so i need to build new brackets that are wide enough to get around the fenders on the trailer and i could remove it pretty easily...
cgmrdc Posted February 24, 2013 Author Posted February 24, 2013 sooooo, as if i wasnt busy enough with work got some upgrades to do to another jeep has put the halt on the MJ... but that just means more money for the build right!? Doing a rear 4 link/ coil conversion with a mixture of ruff stuff and artec parts (normally i build my own brackets but in the interest of time we decided it was best to buy some) i will say I'm extremely impressed with the artec 4 link brackets we got, shipping was super fast too. and as always, you can't go wrong with ruff stuff. cutting off the frame behind the rear seat and redoing some of the cage work, also going to add a fuel cell. and stepping up to 36s Got some friends coming down on thursday for MO to help on the MJ so i sould have a decent update on it next week.
89Comanche4x4 Posted February 25, 2013 Posted February 25, 2013 Wow that sure does look like a chore haha. How much money was all the stuff in the first picture if you don't mind me asking?
