It got realy cold lastnight (5 deg.) and for the first ever my Comanche would not start. The engine turns over freely and has been running great, it tryed to start twice, so obviously I have all of the elements needed to run (suck, squeeze, bang, bolw) are there and I can hear the fuel pump run until the system is pressurized..... So, I guess the question is, Is the 4.0 known for starting hard in the cold and is there a cure for this problem?
Thanks for any help.
Eric
No, it turns over fine and does fire, it started twice on seperate occations and died right away then just turns over.....and over.....and over.....and over, you get the point. My old Grand Wagoneer with a 360 would start in any temp north of 50 below and my Eagle with a 258 never let me down. I lived here in the great white north for 25 years but this is the first time that I have had my Comanche here in the winter and have never experienced a 4.0 in the cold. I guess I'll start with a bottle of Drygas and a can of starting fluid.
No, I have not done that. I will try that in the morning. Some say they bypass them on every or Comanche or Cherokee that they get just to take out the week link. Am I understanding this correctly, the resistor was only put there to cut the voltage to the pump in order to quiet it and that removing it will improve the performance of the pump?
a question of my own do or have you ran gasline antifreeze in your truck?
why thinking ice in fuel filter either choking off or restricking flow
just an idea... B...
Plugs are fresh (less than 500 miles) and yes I did gap them. I never trust a plug that is "factory gapped". Yes, I can hear the pump prime when I turn the key on. No, I have never run gas line antifreeze in this truck, I haven't been driving it that long. After many years in Vermont it is kind of the go to first move when you have this happen.
