CallmeMaybe Posted November 27, 2012 Share Posted November 27, 2012 What is the stock amp for the alternator? Autoparts stores say 61-100ish. They believe I have a 61amp but will the 100amp fit? It has a bigger casing. 1988 4.0L 4x4 Link to comment Share on other sites More sharing options...
flint54 Posted November 27, 2012 Share Posted November 27, 2012 Not sure about the 100 amp, but I can tell you with certainty that the 136 amp from a 99 WJ will require minor trimming to make fit. Link to comment Share on other sites More sharing options...
banshee Posted November 27, 2012 Share Posted November 27, 2012 mine is an 87 4.0L requires 105amp, O-reilly $100 give or take Link to comment Share on other sites More sharing options...
Pete M Posted November 27, 2012 Share Posted November 27, 2012 if you can, take your old one in with you to verify the mounting pattern. Link to comment Share on other sites More sharing options...
ncmountainMJ Posted December 26, 2012 Share Posted December 26, 2012 Not sure about the 100 amp, but I can tell you with certainty that the 136 amp from a 99 WJ will require minor trimming to make fit. Sorry to hijack this post but can you give me more detail or a link to this upgrade? Link to comment Share on other sites More sharing options...
cruiser54 Posted December 26, 2012 Share Posted December 26, 2012 It's a CS-130 Delco alternator. Local generator/starter shops can boost them up for you , too. Don't forget the crappy and small cables your Jeep has. Many times addressing that makes a huge difference. www.kelleyswip.com Link to comment Share on other sites More sharing options...
1987Comanche Posted December 26, 2012 Share Posted December 26, 2012 Non A/C, non HD cooling trucks got the 61 Amp, 4 3/4" case alternator. Adding either of these options gets you the 5 1/4" case alternator (105 amp I believe). The larger case alternator is a direct swap for the smaller one and it's cheaper too! You will, however, likely confuse the people at the parts store... Link to comment Share on other sites More sharing options...
mvusse Posted December 26, 2012 Share Posted December 26, 2012 Non A/C, non HD cooling trucks got the 61 Amp, 4 3/4" case alternator. Adding either of these options gets you the 5 1/4" case alternator (105 amp I believe). The larger case alternator is a direct swap for the smaller one and it's cheaper too! You will, however, likely confuse the people at the parts store... When I bought my truck (no AC, no auxiliary fan or pigtail for one) it had the larger alternator and I would like to think it was original because the bolts all had then 21 years of corrosion. Every single one broke off before it let loose. Link to comment Share on other sites More sharing options...
velco Posted December 26, 2012 Share Posted December 26, 2012 Cold weather package includes the 105 amp alternator. Cool up here today -24C with a -33C wind chill. Link to comment Share on other sites More sharing options...
banshee Posted January 5, 2013 Share Posted January 5, 2013 upgrade from 2007 jeep Compass with 2.0L Engine - 140 Amp part number 31-01280 AR OR upgrade from 2004 Mercedes Benz C240 150 AMPS but slightly harder wiring Part number 31-00096 AR autoparts wherehouse.com Link to comment Share on other sites More sharing options...
