Des88MJ Posted November 4, 2012 Share Posted November 4, 2012 I saw posts about using the Dakota rear brake hose when lifting, does anybody know how much of a lift they can handle? I plan on doing a axle flip with 2 inch blocks, so I guess that'll be 6 inches total. I also need to replace my E-brake cables, I heard about using 2 right side wrangler cables, is that true, and do I need to drop the transfer case? Link to comment Share on other sites More sharing options...
Pete M Posted November 5, 2012 Share Posted November 5, 2012 Dakota hose should be plenty. :thumbsup: but I'd advise against blocks in the rear. Going SOA increases spring wrap. adding blocks to the mix makes it even worse. :( Link to comment Share on other sites More sharing options...
Des88MJ Posted November 5, 2012 Author Share Posted November 5, 2012 Cool, thanks for the info, I'll just add a leaf to my packs for the extra inches, and get bigger anti wrap perches. How about the e-brake cables, any info on those? Link to comment Share on other sites More sharing options...
ncmountainMJ Posted November 5, 2012 Share Posted November 5, 2012 brake cables... and about every thing else you need.... http://eastcoastgearsupply.com/i-4985638-xj-ford-8-8-e-brake-cables.html Link to comment Share on other sites More sharing options...
skidoo_j Posted November 5, 2012 Share Posted November 5, 2012 http://comancheclub.com/topic/30777-10-longer-parking-brake-cables/ Link to comment Share on other sites More sharing options...
Des88MJ Posted November 5, 2012 Author Share Posted November 5, 2012 thanks for the help guys, those doorman cables will work perfect Link to comment Share on other sites More sharing options...
89eliminator Posted November 5, 2012 Share Posted November 5, 2012 you will get about 6" just by doing spring over. how much do you plan on lifting the front? Link to comment Share on other sites More sharing options...
SW86 Posted November 5, 2012 Share Posted November 5, 2012 hell i just bent my hard line a tad and boom, done. Link to comment Share on other sites More sharing options...
Des88MJ Posted November 5, 2012 Author Share Posted November 5, 2012 I got 4 inch lift plus 2 inch pucks for the front. I need new hoses anyways, might as well get longer ones that are actually cheaper than the ones made for my truck. Bending the hard line in the rear would do nothing unless I modify/make a bracket to mount the hose lower, which by the way I'm not doing. Link to comment Share on other sites More sharing options...
Pete M Posted November 5, 2012 Share Posted November 5, 2012 hell i just bent my hard line a tad and boom, done. someone doesn't have a rusty truck. :yes: Link to comment Share on other sites More sharing options...
skidoo_j Posted November 5, 2012 Share Posted November 5, 2012 Cheap Extended brake hoses for the front, would fit xj and mj Napa Part 38182 and 38183 they are about 4" longer not sure what they're from. they cost me 13 each. way better than any other i've found. they have a bracket you need to remove but for the price :) Link to comment Share on other sites More sharing options...
