Des88MJ
    Long Island, NY
Des88MJ's Achievements
  1. Looks horrendous, anybody notice the bent clutch pedal?
  2. going to have to wait until after the holidays, found out it needs a vacuum switch on the back of the transfer case, if I can even get one.
  3. I know many of you guys probably ditched the system, but my issue is that vacuum isn't being supplied to the proper port (has 3 ports) when in 4wd, it was being applied to the port that is for the 4wd light... weird, no big deal I just swapped them around on the trail to get in 4wd. Has anybody else had this issue?
  4. Another good thing to stumble on! Thanks for that, my electrics like to act slightly strange once in a while.
  5. First time seeing this thread, what a build and a half! Props to you man, I can tell you take pride in your work. Got a question though, the 2wd leafs, what was the purpose of using them over the 4wd ones?
  6. Glad I stumbled upon this, I've been looking to replace the cover for the oil issue, now i'm just going to cut the towers, and replace the gasket.
  7. I have that issue randomly, usually I find that a vacuum leak seems to cause it, one of the larger vacuum hoses on my intake swells from oil and loses its seal.
  8. I got 4 inch lift plus 2 inch pucks for the front. I need new hoses anyways, might as well get longer ones that are actually cheaper than the ones made for my truck. Bending the hard line in the rear would do nothing unless I modify/make a bracket to mount the hose lower, which by the way I'm not doing.
  9. thanks for the help guys, those doorman cables will work perfect
  10. Cool, thanks for the info, I'll just add a leaf to my packs for the extra inches, and get bigger anti wrap perches. How about the e-brake cables, any info on those?
  11. I saw posts about using the Dakota rear brake hose when lifting, does anybody know how much of a lift they can handle? I plan on doing a axle flip with 2 inch blocks, so I guess that'll be 6 inches total. I also need to replace my E-brake cables, I heard about using 2 right side wrangler cables, is that true, and do I need to drop the transfer case?
  12. I would like a orange xxl heavy hoodie with green logo
  13. Very nice, I got a doner 89 xj limited, putting all the little goodies into my truck. The buckets I have are power. I noticed that where the seats bolt into the floor is different on both trucks. It doesn't look like I can use the power buckets at all :dunno: I see you have the bench seat track brackets removed, they can only be used on manual buckets I assume, because it doesn't look like I can put the brackets on the power seats :doh:
