Zebvance Posted October 29, 2012 Share Posted October 29, 2012 I was driving the mj around today and I was cruising about 45 and it just turned off on me. I came to a stop and it started right up again and the problem didnt repeat. What caused this? Also I just replaced my valve cover gasket about 1500 miles ago with a high dollar felpro rubber gasket and now all the sudden it is leaking again at the back of the head. I checked the torque specs and it was torqued correctly to the right inch pounds. I gave each bold a extra turn or two and it is still seeping. Any thought? Go get another gasket and replace it again? Link to comment Share on other sites More sharing options...
87Chief Posted October 29, 2012 Share Posted October 29, 2012 Do you have a aluminum or plastic valve cover? Link to comment Share on other sites More sharing options...
Zebvance Posted October 29, 2012 Author Share Posted October 29, 2012 aluminum Link to comment Share on other sites More sharing options...
cruiser54 Posted October 30, 2012 Share Posted October 30, 2012 Check your CPS wiring and make sure it's not near the exhaust manifold. Link to comment Share on other sites More sharing options...
JFAComanche6 Posted October 30, 2012 Share Posted October 30, 2012 Id get a paper gasket with some bonded gasket to put around it. I put a rubber gasket on my oil pan and I was not impressed. Link to comment Share on other sites More sharing options...
88mjgilley Posted November 1, 2012 Share Posted November 1, 2012 sounds like you cps is going out to me also my old 95 did that all the time untill i replaced it Link to comment Share on other sites More sharing options...
Jerry Posted November 2, 2012 Share Posted November 2, 2012 +1 CPS It seems to be the main culprit in random go/no go symptoms. I had the same, replaced the CPS and that cured it immediately. It's a bugger to get at tho! Link to comment Share on other sites More sharing options...
Zebvance Posted November 2, 2012 Author Share Posted November 2, 2012 Thanks guys! I started looking at the valve cover more and the oil may be coming from the oil fill cap and the two CCv hose grommet. None of them have a good seal. Just replaced the back hose about 10 mins ago. The front is new. But I need to get it to seal good on the valve cover some how. And as far as the oil fill cap goes it looks like its just old and dry rotted so I need a new one that has a fresh gasket on it. I start at those places. Link to comment Share on other sites More sharing options...
cruiser54 Posted November 2, 2012 Share Posted November 2, 2012 Have you tested your CPS? You're right on regarding replacing the oil cap. Link to comment Share on other sites More sharing options...
Zebvance Posted November 2, 2012 Author Share Posted November 2, 2012 Also the rear main could be part of the problem and oil pan gasket. I have a new oil pan cause mine is rusted and I bought a brand new fel-pro rubber gasket for it too. But I want to replace the rear main at the same time I do that. After research on replacing the rear main I would like to find a professional to do the job. I want to do it once and never have to do it again and from what I can tell if your a beginner at doing it, it might take a couple try's. Link to comment Share on other sites More sharing options...
