martin809 Posted October 6, 2012 Share Posted October 6, 2012 I have found a 96 xj dash. I am going to put it in a 92 Comanche. I will remove entire dash and sensors. Is there anything else I should get. And is this a direct bolt in. I am taking it from a 96 2 door xj. The guy is only taking th emotor out. He said I can have anything else. BTW my dash is tore up that is why I am doing this Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 6, 2012 Share Posted October 6, 2012 Dash seats center console carpet make it pretty. :} Link to comment Share on other sites More sharing options...
shelbyluvv Posted October 6, 2012 Share Posted October 6, 2012 I know the 96 is OBD-II where the 91 is OBD-I. The steering column is also totally different. You will most likely need all the underhood wiring as well. Link to comment Share on other sites More sharing options...
mvusse Posted October 6, 2012 Share Posted October 6, 2012 Early 96 and late 96 make a difference. Early 96 they piggybacked the OBD II stuff onto the OBD I harness, late 96 they started using the 97 harness. But if you swap just the dash and not the wiring, there should be no problem. I also don't know why the steering column would be different between 92 and 96. Link to comment Share on other sites More sharing options...
shelbyluvv Posted October 6, 2012 Share Posted October 6, 2012 Air bag Link to comment Share on other sites More sharing options...
martin809 Posted October 6, 2012 Author Share Posted October 6, 2012 Thanks for the repilies. I will look at it all. I am on my way now to check it out. If it has air bags and a late 96. I guess I will keep looking. Link to comment Share on other sites More sharing options...
martin809 Posted October 6, 2012 Author Share Posted October 6, 2012 Just got back from looking at the dash. It does have an air bag. I just need the dash because mine is cracked. I do want to use the gauge cluster because it will get ride of the idiot lights and give me a tach. can I use this dash without changing the wiring. I don't mean to sound stupid but this is my first dash swap. Link to comment Share on other sites More sharing options...
Alexia Posted October 7, 2012 Share Posted October 7, 2012 On 10/6/2012 at 8:14 PM, martin809 said: Just got back from looking at the dash. It does have an air bag. I just need the dash because mine is cracked. I do want to use the gauge cluster because it will get ride of the idiot lights and give me a tach. can I use this dash without changing the wiring. I don't mean to sound stupid but this is my first dash swap. You should change the wiring and it is easy to do so. It just holds in with ties and clips. Link to comment Share on other sites More sharing options...
mvusse Posted October 7, 2012 Share Posted October 7, 2012 On 10/6/2012 at 3:08 PM, shelbyluvv said: Air bag :doh: Link to comment Share on other sites More sharing options...
