glundblad Posted September 30, 2012 Posted September 30, 2012 I know there are quite a few Amsoil fans on this forum and I need advice. I was on another forum and a guy bought some of this stuff "Amsoil Heavy Duty metal protector". http://www.amsoil.co...efront/amh.aspx and sprayed his entire frame on his new truck. I am ditching my somewhat new and very disliked POS z71 Chevy Tahoe daily driver and getting something different. I live in Northern Indiana and on a dirt road. I keep my trucks for 10 years and want them to last. The guy on the other forum sprayed the entire undercarriage of his truck. It dried to a waxy haze and it seemed to keep his chassis very lubricated and free of dirt and rust. It is really not very expensive. It never hardens completely so bolts will always work. It is an oil base so it always wicks. He said 4 cans did a full size truck. Since my MJ got back from the body shop a couple of years ago, I was thinking of spraying this junk on the frame along with my JK. The rear leafs on my MJ have never seen winter but they still have minor surface rust on them. I think this stuff would prevent that. Plus it looks like it would keep new parts looking new. Anyone used it?
HOrnbrod Posted September 30, 2012 Posted September 30, 2012 I have not used it but was considering a similar product. Since you live on a dirt road, I imagine the hardest part of the job would be surface prep. Getting all that mud and sand caked up in all the creases and crevices off the undercarriage would be a tough job. I would think the coating would last a lot longer sprayed on a clean surface.
glundblad Posted September 30, 2012 Author Posted September 30, 2012 The other products compared was something called Boeshield and the other was Fluidfilm. I agree about the surface prep. DIrt roads are a tough environment. I thought I would hit it right when I got the truck. According to the post, it took 3 days to dry before he drove it IIRC.
Pete M Posted October 1, 2012 Posted October 1, 2012 be aware of any drain holes in the body and don't plug them or you'll end up encouraging rust on other places. :thumbsup:
knever3 Posted October 1, 2012 Posted October 1, 2012 After reading the AMSOIL web page description it looks like it's basically identical to Castrol's "Chain Wax". I used it on my Suzuki GSX-R'S chain. You needed to ride it for a couple of miles because the wax sticks better with a little heat. I sprayed the chain with brake parts cleaner first before applying. The idea is to lubricate and seal with the wax, repells water and dust. http://www.amazon.com/Castrol-Chain-Wax-8oz-12367/dp/B002KOCL7Y/ref=pd_sim_sbs_auto_1
danbyrambler Posted October 1, 2012 Posted October 1, 2012 PENETROL's a snake oil that's been around forever - I've used it on cars.trucks, farm implements that stay outdoors, battery terminals, equipment/fabrication prep & wart remover - You can pretty much believe what's on the label/directions - Oil based, you can paint over it - The big box stores carry it - Good Stuff Image Not Found
Incommando Posted October 2, 2012 Posted October 2, 2012 Rust Prevention Advice Needed + Location: Larwill, Indiana = Best advice? Move... :banana:
glundblad Posted October 3, 2012 Author Posted October 3, 2012 Rust Prevention Advice Needed + Location: Larwill, Indiana = Best advice? Move... :banana: You are not much help! :rotf:
