wthayer Posted February 26, 2007 Share Posted February 26, 2007 hello, i just bought a 98 cherokee and I'm wondering if 31x10.50x15 on 15x7 stock rims would fit with a 2 inch lift? i know its not a comanche but you guys have been a big help too me so far. thanks Link to comment Share on other sites More sharing options...
Eagle Posted February 26, 2007 Share Posted February 26, 2007 They'll fit with no lift, if you're on stock Jeep rims. However, with OR without the lift, at full steering lock (when you turn the wheel all the way left or right) they are going to rub on the lower control arms. This condition is not helped by a lift. Link to comment Share on other sites More sharing options...
DirtyComanche Posted February 26, 2007 Share Posted February 26, 2007 But, with a 2" lift and some lower BS rims, it won't rub the LCAs. Of course, then you need longer bumpstops or you'll hammer your fenders. Or just cut the fenders... I run 31x10.5s on my DD cherokee on a 2"~ budget lift. Link to comment Share on other sites More sharing options...
87manche Posted February 27, 2007 Share Posted February 27, 2007 or you can shim the steering stops, you'll lose a small amount of turning radius. http://stu-offroad.com/steering/stop/steerstop-1.htm Link to comment Share on other sites More sharing options...
JeepcoMJ Posted February 27, 2007 Share Posted February 27, 2007 hello, i just bought a 98 cherokee and I'm wondering if 31x10.50x15 on 15x7 stock rims would fit with a 2 inch lift? i know its not a comanche but you guys have been a big help too me so far. thanks don't go that wide on 15x7 rims. they will curve too far outward then and will wear faster. good rule of thumb for 10.50 tires is 8"wide rims to 10" wide. jeep had factory ones like that. I say this from experience. I've got 31x10.50 Dayton Timberline A/T's on 8" wide rims for my 86 comanche and at 17k miles on them they look like new. my brother has the same tires on his 88 comanche with 22k miles on them, but 7 " rims and they wore funny cause of the curve on the riding surface that was brought on by the narrower rim. he has to buy new ones when he starts driving again. Link to comment Share on other sites More sharing options...
feerocknok Posted February 27, 2007 Share Posted February 27, 2007 hello, i just bought a 98 cherokee and I'm wondering if 31x10.50x15 on 15x7 stock rims would fit with a 2 inch lift? i know its not a comanche but you guys have been a big help too me so far. thanks don't go that wide on 15x7 rims. they will curve too far outward then and will wear faster. good rule of thumb for 10.50 tires is 8"wide rims to 10" wide. jeep had factory ones like that. I say this from experience. I've got 31x10.50 Dayton Timberline A/T's on 8" wide rims for my 86 comanche and at 17k miles on them they look like new. my brother has the same tires on his 88 comanche with 22k miles on them, but 7 " rims and they wore funny cause of the curve on the riding surface that was brought on by the narrower rim. he has to buy new ones when he starts driving again. Beads'll pop off easier on an 8" rim with only 10.5s, so it kinda depends on the trucks usage. Link to comment Share on other sites More sharing options...
87manche Posted February 27, 2007 Share Posted February 27, 2007 hello, i just bought a 98 cherokee and I'm wondering if 31x10.50x15 on 15x7 stock rims would fit with a 2 inch lift? i know its not a comanche but you guys have been a big help too me so far. thanks don't go that wide on 15x7 rims. they will curve too far outward then and will wear faster. good rule of thumb for 10.50 tires is 8"wide rims to 10" wide. jeep had factory ones like that. I say this from experience. I've got 31x10.50 Dayton Timberline A/T's on 8" wide rims for my 86 comanche and at 17k miles on them they look like new. my brother has the same tires on his 88 comanche with 22k miles on them, but 7 " rims and they wore funny cause of the curve on the riding surface that was brought on by the narrower rim. he has to buy new ones when he starts driving again. you can get proper wear out of a 10.5 tire on a 7" rim. You need to chalk the tires to get the proper footprint. It sounds like he was running too much pressure, so he wore the center of the tread. I run 10.5's on the stock rims for road tires. I run 30 PSI front, and 28 rear when unloaded. I ran 45 PSI in the rears on the trip to MO because there was 1200 lbs of weight in the bed. Link to comment Share on other sites More sharing options...
Eagle Posted February 28, 2007 Share Posted February 28, 2007 don't go that wide on 15x7 rims. they will curve too far outward then and will wear faster. good rule of thumb for 10.50 tires is 8"wide rims to 10" wide. jeep had factory ones like that I ran my MJ with 31x10.50s on stock 7" rims for several years and I didn't notice any odd or accelerated tire wear. Link to comment Share on other sites More sharing options...
wthayer Posted February 28, 2007 Author Share Posted February 28, 2007 thanks everyone. i got a set of 31x10.50 bfg all terrains. i love them. they do fit without a lift but i have rubbing mainly in the rear, especially with some added weight inside. thanks for all the info. Link to comment Share on other sites More sharing options...
carnuck Posted March 2, 2007 Share Posted March 2, 2007 I'm running 33/9.50s on my stock rims. Before these, I has ZJ alloys with 255/85/16s (33.5/10/16) on with my SOA, but they clipped the fender liner on hard corners. Link to comment Share on other sites More sharing options...
