TylerJY Posted September 6, 2012 Posted September 6, 2012 My soa lifted me too much with stock 4x4 leafs, if I swap Xj shackles on will it lower the rear a bit?
TylerJY Posted September 7, 2012 Author Posted September 7, 2012 So 2wd leaf springs would probably be my best bet?
Pete M Posted September 7, 2012 Posted September 7, 2012 2wd MJ leafs will sit you a bit lower. as will other leafs out of XJs and whatnot. it's a bit of a hassle mixing and matching, but you should be able to lower it a bit with leafs that have less arch. In fact, the first I'd try is a full XJ pack. Cut the eyes off and put the whole thing under your current MJ main. :thumbsup:
mountainman Posted September 7, 2012 Posted September 7, 2012 2 100 lb sand bags right by the tailgate will do it. :)
Comanche County Posted September 7, 2012 Posted September 7, 2012 If you don't plan on hauling a lot of weight you can remove the overload spring also.
Pete M Posted September 7, 2012 Posted September 7, 2012 I wouldn't do that. you'll need the overload to help fight springwrap.
