So far I've found one Comanche in a jy around here. It had good bed sides above the wheel wells, but I've got them now!
My 88 MJ has rust on the driver's side, so I'll be using that sheet metal. The rest may be available if my passenger side is good and my flares can be re-used.
Mine just shows perforation right above the flare and it's solid above that. I think I have enough with a little to spare.
Alexia - you really did find gold at the jy!
2 XJs make nice donors too
Except that the XJ wheels arches are shorter than MJ arches in both length and height. And the 2-door XJ are the same size as the 4-door -- they both take the same flares, which are smaller than MJ rear flares.
I am glad I did not buy those rear flares from the junk yard yesterday!
