E4Marty Posted August 7, 2012 Share Posted August 7, 2012 Well the most important issue I'm having is that the switch for the vents only works in the off and only runs on defrost regardless of postion. Is the selector the switch is connected too the culprit? My driver side front speaker is somehow causing the sound to cut out from bass or volume. The odd part is, it's only when the door is shut that it'll cut out, with it open the sound works fine. I've only got the +\- wires hooked up to the aftermarket speakers, the black wire on the connector isn't hooked to anything. Link to comment Share on other sites More sharing options...
relyt120 Posted August 8, 2012 Share Posted August 8, 2012 That vent problem sounds like a vacuum issue, check the lines. I had the same issue on mine reconnected one line and boom its fixed. :wrench: Link to comment Share on other sites More sharing options...
E4Marty Posted August 8, 2012 Author Share Posted August 8, 2012 What line did you fix? It's an electronic device behind the panel so I don't understand how a vacuum could be it. Link to comment Share on other sites More sharing options...
Pete M Posted August 8, 2012 Share Posted August 8, 2012 vacuum actuates the little diverters in the dash. a common leak is the hose running to the vacuum reservoir behind the front bumper. Link to comment Share on other sites More sharing options...
Zenobian_84 Posted August 8, 2012 Share Posted August 8, 2012 vacuum actuates the little diverters in the dash. a common leak is the hose running to the vacuum reservoir behind the front bumper. Actually, I'll have to check that one. Still haven't gotten around to solving mine... :oops: I'll just take the easy route and say it's been laziness :D Link to comment Share on other sites More sharing options...
Comanche County Posted August 9, 2012 Share Posted August 9, 2012 vacuum actuates the little diverters in the dash. a common leak is the hose running to the vacuum reservoir behind the front bumper. ...on the passenger side. Link to comment Share on other sites More sharing options...
