dinghyboy Posted August 3, 2012 Posted August 3, 2012 I'll call it the grill surround. It's that fiberglass panel in front of the hood and above the grill. On my 92 comanche it's cracked. What year cherokee panels can i use to replace it. I'm sure Jeep changed it sometime just have no idea when. Thanks, Gavin
Minuit Posted August 3, 2012 Posted August 3, 2012 Some digging tells me that '91-'96 will fit right in. I have no idea what the differences between the other years are, sorry. :thumbsup: P.S: The technical term is 'header panel'.
starkizer Posted August 10, 2012 Posted August 10, 2012 in or around 92 they changed the body style a little bit to the squared off look, so don't get anything before 91 or it will be for the round-er look. the other guy has the years right, and it is a header panel. So all in all, the other guy had it. Just wanted to throw that bit in there about the body style! :D
yellaheep Posted August 10, 2012 Posted August 10, 2012 I dunno what starkizer is smoking...... But any header panel '84 - '96 can be made to work...... The body lines are the same. It's the mounting hardware that differs. '84 - '86 bolt to the fenders a little differently than '87 - '96. Some minor differences in bezel/grill pieces and how they screw on as well..... But again, it can all be made to work. Body lines changed in '97 - '01. To answer the original poster's question, a '91 - '96 header panel will be a direct replacement for his '92.
Eagle Posted August 10, 2012 Posted August 10, 2012 I dunno what starkizer is smoking...... But any header panel '84 - '96 can be made to work...... The body lines are the same. It's the mounting hardware that differs. '84 - '86 bolt to the fenders a little differently than '87 - '96. Some minor differences in bezel/grill pieces and how they screw on as well..... But again, it can all be made to work. Body lines changed in '97 - '01. To answer the original poster's question, a '91 - '96 header panel will be a direct replacement for his '92. Body lines changed in 1997 -- Correct. '91 - '96 is direct replacement for '92 -- Also Correct. The '84 - '90 (or maybe '89) header and grille look the same from a few feet away, but they ARE different. On the early ones, the horizontal trim piece across the top of the grille and headlight bezels is a separate piece (three separate pieces, if you include the headlight bezels). Those pieces attach to the header panel. Chrysler changed the design to make those integral to the grille and headlight doors, and the Chrysler design thus requires a different header panel. If you ONLY need the header panel but your grille and headlight bezels are intact -- get the 91 - 96 header. If you also need a grille and headlight bezels, you can go either way, but you have to get all the pieces from the same range of years.
yellaheep Posted August 10, 2012 Posted August 10, 2012 What Eagle said isn't wrong..... but I'll argue that the earlier header panels will still work with the 91 thru 96 trim pieces. :thumbsup:
starkizer Posted August 17, 2012 Posted August 17, 2012 I'm not 100% sure but I feel like I should be offended some how! :nuts: oh well.
