dinghyboy Posted August 1, 2012 Share Posted August 1, 2012 New here and almost embarressed to ask this question since you all might question whether or not I should have a comanche. Is there a secret to geting to the light bulb on the interior post lights? I'm a little leary of prying on 20 year old platic lenses, but have to get some illumination in the cab. Thanks Gavin 92 Comanche I promise I'll post a picture and more information once I get a few minutes. Link to comment Share on other sites More sharing options...
Harley Posted August 1, 2012 Share Posted August 1, 2012 The whole assembly just snaps in and out. Link to comment Share on other sites More sharing options...
RDAN1 Posted August 1, 2012 Share Posted August 1, 2012 New here and almost embarressed to ask this question since you all might question whether or not I should have a comanche. Is there a secret to geting to the light bulb on the interior post lights? I'm a little leary of prying on 20 year old platic lenses, but have to get some illumination in the cab. Don't try to pry the lenses out..as stated above the whole fixture will come out of the pillar if you gently pry it out..held by 2 plastic clips built into one end of the fixture. Then you can remove the bulb from the side..While it's out, clean up everything, especially all the contacts. Good Luck. Link to comment Share on other sites More sharing options...
flint54 Posted August 1, 2012 Share Posted August 1, 2012 Welcome aboard!! You are wise to be leery of prying on 20 year old plastic. The tabs that hold the light assembly (not the lens as pointed out) seem notoriously brittle. I've been batting about 50/50 at the JY, many are already broken. However, there is a suitable replacement light available, if you're not stuck on exact originality. Work it like an eggshell full of black ink over your wife's linen tablecloth. How about some details on your 92? Link to comment Share on other sites More sharing options...
TylerJY Posted August 1, 2012 Share Posted August 1, 2012 What's the build date on your truck? Link to comment Share on other sites More sharing options...
dinghyboy Posted August 2, 2012 Author Share Posted August 2, 2012 Thanks for the cautions and guidance. The comanche is a 1992, 4.0L HO with automatic trans, 4WD, and Air conditioning. It is green with a biege interior and bench seat. I think it has been repainted some time in its life. The build date is 2/92. It has not been raised and is generally unmolested. I haven't measured the bed but I think it's a long bed. It has very little rust that I've found so far but I really haven't had a chance to pull the carpets yet. Looks solid from underneath. I don't know how much I'll actually get to use it since my two teenage daughters are already fighting over it. Gavin Link to comment Share on other sites More sharing options...
ComancheKid45 Posted August 2, 2012 Share Posted August 2, 2012 Sorry its a bit off topic....but do you happen to have any exterior pictures of your truck? Link to comment Share on other sites More sharing options...
dinghyboy Posted August 3, 2012 Author Share Posted August 3, 2012 No pictures yet, waiting to wash it then shoot some. Was there something specific you wanted a shot off? Please don't tell my truck is stolen and it's really yours. As a follow up, The bulbs were fine. I wasn't able to get the lights out (chivken) so I just flipped the lens back and forth about 20 times each and they started working. Guess the contacts in the light housing are coroded, but they're good for now. Gavin Link to comment Share on other sites More sharing options...
ComancheKid45 Posted August 3, 2012 Share Posted August 3, 2012 Ha Ha no It aint mine, You just mentioned you have a green 1992 Comanche......theres an ongoing discussion about if theyre are any Green 92s left out there and you may just be the person were lookin for! Link to comment Share on other sites More sharing options...
