Dedaw Posted August 1, 2012 Share Posted August 1, 2012 Hey all, I'm new here, and haven't taken the time to post an intro or pictures of my truck (which I plan to do soon). Anyways, I've been tossing around the idea of a new bench seat (which my truck needs BAD), and was wondering if anyone here has done one, and what they used. I'd do the captain's chair swap, but I bought a truck with a bench seat for a reason. ( :roll: ) The drivers side sags terribly, as in my little sister that barely comes up to shoulders sits higher than me. It's awesome when you're driving a girl around and she sits several inches higher than you because there is no seat support left. :nuts: Thanks for any input. Link to comment Share on other sites More sharing options...
MJRemi Posted August 1, 2012 Share Posted August 1, 2012 The floor brackets are specific to Comanches so if you go with a different seat, like Ranger for instance, you'll need to use MJ brackets or fab something up. The simplest solution would be to have your seat reupholstered at a local shop and have the cushion built to your specs. Link to comment Share on other sites More sharing options...
Abyx Posted August 1, 2012 Share Posted August 1, 2012 viewtopic.php?f=2&t=36300&hilit=ranger+bench Here's some info on a ranger bench seat swap; also there's info in there on the dakota bench seat swap. Both are good options, but IMO I like the ranger seat better because the bench is even with the buckets. Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted August 2, 2012 Share Posted August 2, 2012 here is one of the better bench swaps that i've seen. http://www.comancheclub.com/forums/viewtopic.php?f=7&t=17196 Link to comment Share on other sites More sharing options...
Dedaw Posted August 2, 2012 Author Share Posted August 2, 2012 Thanks guys! I didn't think of the ranger bench. I'll probably go with that one. :cheers: edit: @Remi: Wouldn't that cost quite a bit? Link to comment Share on other sites More sharing options...
MJRemi Posted August 2, 2012 Share Posted August 2, 2012 Dedaw said: Thanks guys! I didn't think of the ranger bench. I'll probably go with that one. :cheers: edit: @Remi: Wouldn't that cost quite a bit? You'd have to check a couple shops but to have the OE seats in near perfect condition would be a nice feature for the truck. I would guess a quality job will be $250-$350. Link to comment Share on other sites More sharing options...
Dedaw Posted August 2, 2012 Author Share Posted August 2, 2012 Wouldn't be THAT bad. I'll have to look around. Link to comment Share on other sites More sharing options...
mnkyboy Posted August 2, 2012 Share Posted August 2, 2012 Abyx said: http://www.comancheclub.com/forums/viewtopic.php?f=2&t=36300&hilit=ranger+bench Here's some info on a ranger bench seat swap; also there's info in there on the dakota bench seat swap. Both are good options, but IMO I like the ranger seat better because the bench is even with the buckets. FYI the Dakota seats sit level too. Mine don't because I wanted the buckets to sit lower which isn't an option with the Ranger seats. Link to comment Share on other sites More sharing options...
