johnr Posted July 22, 2012 Posted July 22, 2012 before it gets cold i need to ask. my heater blower only works on high. i put a new motor in it because it was squeeling really badly but now i only have high speed. is my switch gone?
Eagle Posted July 22, 2012 Posted July 22, 2012 Nope. Your resistor pack is gone. The switch can only turn power on and off, it can't control speed. To do that, there's a resistor pack under the dashboard on the passenger side. High speed is full power, so no resistor. The slower speeds all have power directed through resistors of varying resistances. They are in a unitized assembly that gets replaced as a package. Typically, when the resistors burn out you have a fan that's either OFF or runs at full speed.
ftpiercecracker1 Posted July 22, 2012 Posted July 22, 2012 I have a little isuzu that had the exact same problem, i unplugged the electrical plug that plugs into the back of the air controler and found corrosion on the tabs. Once i cleaned them up it has worked like new. might save you from having to tear apart your dash.
johnr Posted July 22, 2012 Author Posted July 22, 2012 Nope. Your resistor pack is gone. The switch can only turn power on and off, it can't control speed. To do that, there's a resistor pack under the dashboard on the passenger side. High speed is full power, so no resistor. The slower speeds all have power directed through resistors of varying resistances. They are in a unitized assembly that gets replaced as a package. Typically, when the resistors burn out you have a fan that's either OFF or runs at full speed. well that sucks. anyone have a picture of what this looks like. maybe i can find one at the junkyard
flint54 Posted July 22, 2012 Posted July 22, 2012 It's really simple. One connector, two screws, and around $20 new. Item #9 in the image. Can get here, or other sources as well. I happen to like these folks: http://www.jeep4x4center.com/resistor-b ... 36000.html
Pete M Posted July 22, 2012 Posted July 22, 2012 don't bother with the junkyard. they are likely as bad as yours. it's a common issue with all sorts of cars/trucks. I've replaced them in about a dozen different things so far. hardest was the 96 grand marquis. that one sucked. :ack:
jimoshel Posted July 23, 2012 Posted July 23, 2012 A recent scientific study has proven that when replacing a bad part a new one will last longer because it is new. A recent scientific study has proven that when replacing a bad part a used one will last longer because any bad ones have already quit but a used one that still works has proven that it's good.
johnr Posted July 23, 2012 Author Posted July 23, 2012 :doh: oh yeah, the auto parts store, thats the ticket ,yeah i could try that, they probably have one there. its closer to :dunce:
johnr Posted July 24, 2012 Author Posted July 24, 2012 :D ah the simple things in life, like having all the fan speeds on your heater blower for under $10.00 bucks. thanks agian for good info :cheers:
