87Chief Posted July 8, 2012 Posted July 8, 2012 I have a problem.. When I go over a bump at about 30 miles an hour, I hear some rubbing in the back.. I took a look back there and I can see some of the metal on the frame (bed?) is rubbed off where it looks like the tire is making contact.. I have the alloy wheels (not sure what they are called, but with the little Jeep on the outside) and size 265/75/15 tires. Is it because of my tire size or.. what? Thanks!
Pete M Posted July 8, 2012 Posted July 8, 2012 a pair of quality hub-centric wheel spacers will cure that. :thumbsup: and as a bonus they will push the tires out to better match the look of the front. :yes:
Paul Bruchal Posted July 8, 2012 Posted July 8, 2012 Yes Pete is right, Spacers will fix that. I was just wondering, what size tires and what size lift do you have? if you have a lift.
87Chief Posted July 8, 2012 Author Posted July 8, 2012 265/75 15 tires (31x10.5 15) and a 2" budget boost (Chevy drop shackles)
Eagle Posted July 8, 2012 Posted July 8, 2012 A 265/75-15 works out to 31.6" diameter by 10.4" width. Most 31s are around 30.5" in diameter, so these are approximately equivalent to a 32x10.50. On stock rims, the inner sidewall is very close to the sheet metal and to the springs. I ran 31x10.50s on my '88 for a couple of years with factory rims. I didn't have any problems on the street, but any time I took it trail riding I came home with rubber marks on the inner fenders at the rear wheels. Any spacer will alleviate this, you don't really need more than about 1/4" to 3/8" to keep a 10.50 from rubbing in the rear.
87Chief Posted July 8, 2012 Author Posted July 8, 2012 Awesome, thanks guys! What is the size spacer that most of us MJer's get to match the front? Was it a 2"?
MJRemi Posted July 8, 2012 Posted July 8, 2012 Awesome, thanks guys! What is the size spacer that most of us MJer's get to match the front? Was it a 2"? The most common, high quality spacer is Spidertrax 1.25". They are hub-centric and, if you go to their website, you'll find "blemish" sets for sale for about $20 less which do not sacrifice quality or performance.
