CoryMJ89 Posted June 29, 2012 Share Posted June 29, 2012 any thoughts on chevy 63's anyone out there ever done this swap? Link to comment Share on other sites More sharing options...
Pete M Posted June 29, 2012 Share Posted June 29, 2012 what's a chevy 63? Link to comment Share on other sites More sharing options...
landlubber Posted June 29, 2012 Share Posted June 29, 2012 leaf spring? Google Search Results Link to comment Share on other sites More sharing options...
jimoshel Posted June 29, 2012 Share Posted June 29, 2012 what's a chevy 63? Didn't want to embarrass myself so was waiting for someone else to ask. :oops: Link to comment Share on other sites More sharing options...
Pete M Posted June 29, 2012 Share Posted June 29, 2012 any thoughts on chevy 63's anyone out there ever done this swap? d'oh. :doh: I knew that too. stupid brain :fs2: MJs leafs are only like 54 inches long so the chevys would be too long. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 29, 2012 Share Posted June 29, 2012 MJs leafs are only like 54 inches long so the chevys would be too long. 57" eye-to-eye actually. :cheers: Link to comment Share on other sites More sharing options...
Pete M Posted June 29, 2012 Share Posted June 29, 2012 54... 57... one of those numbers 'round there... :rotf: Link to comment Share on other sites More sharing options...
landlubber Posted June 30, 2012 Share Posted June 30, 2012 are both SWB and LWB springs the same length? Link to comment Share on other sites More sharing options...
Pete M Posted June 30, 2012 Share Posted June 30, 2012 yup. :thumbsup: Link to comment Share on other sites More sharing options...
CoryMJ89 Posted June 30, 2012 Author Share Posted June 30, 2012 i know they be to long. and would have to re mount the spring up further but anyone done it before i know the 63s flex pretty good. on the mjs its usally the front doing most the work on the flex the rear yeah does okay just not enough to keep up Link to comment Share on other sites More sharing options...
whowey Posted June 30, 2012 Share Posted June 30, 2012 what's a chevy 63? Had one... it had a 327 in it... got me into WAAAAYYYYY too much trouble... Link to comment Share on other sites More sharing options...
Pete M Posted June 30, 2012 Share Posted June 30, 2012 i know they be to long. and would have to re mount the spring up further but anyone done it before i know the 63s flex pretty good. on the mjs it's usually the front doing most the work on the flex the rear yeah does okay just not enough to keep up My leafs flexed from one maximum to the other, no problemo. even had an extra main leaf shoved in there to help reduce spring-wrap. My personal view is that a many guys are running a front end that's a bit too flexy for most terrains. and combine that with almost no weight over the rearend, you get an unbalanced system. but either way, before going all gung-ho on fabbing in new leafs, find the spring rates of both and compare. :thumbsup: Link to comment Share on other sites More sharing options...
ParadiseMJ Posted July 1, 2012 Share Posted July 1, 2012 The chevy springs that I TRIED to use had an offset center hole. I tried to drill a different hole...no go with my equipment. I called several machine shops who said they were not set up to drill through a 3/8" thick spring. The only option was a diamond tip bit...nobody had one. I gave up and just used a S-10 main with the eyes cut off. Why was it easier to CUT the spring than DRILL it... :dunno: Link to comment Share on other sites More sharing options...
Pete M Posted July 1, 2012 Share Posted July 1, 2012 what were you cutting with? Link to comment Share on other sites More sharing options...
