NTXMancheman Posted June 29, 2012 Share Posted June 29, 2012 sorry I didn't have an intro but i live in TX and its been in the 100's for the past few days and its TERRIBLE with no a/c. I have the old r12 system and I'm trying to figure out what ways to have a working a/c as fast as possible and wondering what my options would be. I was thinking about doing the conversion but don't know what's involved. I would be doing it myself and I would consider myself somewhat mechanically inclined. the other option was NAPA makes a super cheap conversion with some oil and a couple different adapters. Has anyone used this? I purchased it but I'm not to sure on it. what would you guys suggest? I HAVE to have A/c!!!!! its TEXAS!!! Link to comment Share on other sites More sharing options...
jimoshel Posted June 29, 2012 Share Posted June 29, 2012 I appreciate your situation. It's been 106 here the last 4 days. Since you already have the NAPA conversion, just go with it. Link to comment Share on other sites More sharing options...
NTXMancheman Posted June 29, 2012 Author Share Posted June 29, 2012 I appreciate your situation. It's been 106 here the last 4 days. Since you already have the NAPA conversion, just go with it. I was wondering if anyone else has used it and if it was any good. Link to comment Share on other sites More sharing options...
Eagle Posted June 29, 2012 Share Posted June 29, 2012 I appreciate your situation. It's been 106 here the last 4 days. Since you already have the NAPA conversion, just go with it. I was wondering if anyone else has used it and if it was any good. I haven't used it, but my brother's best friend is a retired Jeep service manager. He has done at least 50 of these conversions and he says they work fine. Link to comment Share on other sites More sharing options...
mountainman Posted June 29, 2012 Share Posted June 29, 2012 reseal the system and charge it with R12. 134 sucks. Link to comment Share on other sites More sharing options...
JeffN Posted June 29, 2012 Share Posted June 29, 2012 I did the napa conversion and it works fine Link to comment Share on other sites More sharing options...
cruiser54 Posted June 29, 2012 Share Posted June 29, 2012 I did the napa conversion and it works fine Me, too. Did it on both my Jeeps. Blows 42* out the vents with 134a. Link to comment Share on other sites More sharing options...
NTXMancheman Posted June 29, 2012 Author Share Posted June 29, 2012 how hard is the conversion to do myself? it came with no instructions Link to comment Share on other sites More sharing options...
dasbulliwagen Posted June 29, 2012 Share Posted June 29, 2012 Basic instuctions are: Install the fittings, use a vacuum pump with correct hookups to pull a vacuum on the system for about an hour to remove any old remaining oil, install new R134a refrigerant, and add new oil to the system. Youll also need to find the original spec for the amount of R12 and convert that amount to the needed amount of R134a. If your old system didnt have any refrigerant left in it, its possible that it leaked out, and that your new refrigerant will leak out as well. Then youll need to figure out what parts are leaking and replace them and start over again. Then theres the procedure for the valves on top of the compressor.... I can't really explain those right now. Thats how you do it right. Link to comment Share on other sites More sharing options...
NTXMancheman Posted June 29, 2012 Author Share Posted June 29, 2012 so most likely I'm going to have to have someone with more experience with A/C Link to comment Share on other sites More sharing options...
Automan2164 Posted June 30, 2012 Share Posted June 30, 2012 so most likely I'm going to have to have someone with more experience with A/C To properly do it, it's best to take it somewhere where they can draw it down under vacuum, leak test it, and charge the system proper. Moisture is your enemy, without a vacuum pump, it's tough to clear the system as needed. Check your components for obvious leaks or damage, then take it to a shop. Rob :cheers: Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 30, 2012 Share Posted June 30, 2012 R12 is still cheap and easy to get here, plus I have a stash. I've had a few R12 vehicles converted in the past, but it was never the same after the conversion. I'll stick with R12 as long as I can. Link to comment Share on other sites More sharing options...
JFAComanche6 Posted June 30, 2012 Share Posted June 30, 2012 My friends and I tried putting the 134 conversion oil in my system and it wouldnt even get out of the can, and we had it hooked to the post on the right with the max a/c going. There was absolutely nothing in the system given it sat for 8 years before I got to it, so what am I doing wrong? :???: Link to comment Share on other sites More sharing options...
