jeeplover88 Posted June 8, 2012 Share Posted June 8, 2012 Hey guys, I'm just wondering if any of you guys would know why my comanche makes a "clunk" noise when I turn my wheel to the right? It only makes the noise when turning right, and I can feel when it makes the sound. Any help would be greatly appreciated! Thanks guys :Canadaflag: :D Link to comment Share on other sites More sharing options...
Pete M Posted June 8, 2012 Share Posted June 8, 2012 check the track bar. chances are that the upper end (drivers side) is either worn out or loose. Link to comment Share on other sites More sharing options...
jimoshel Posted June 8, 2012 Share Posted June 8, 2012 The right side lower rear control arm bushing was the culprit on my "87. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 8, 2012 Share Posted June 8, 2012 Tighten the track bar bracket where it mounts to the frame while you're down there. They don't look loose, but the bolts can be. Process of elimination and this is a known issue. Link to comment Share on other sites More sharing options...
Dadinator Posted June 9, 2012 Share Posted June 9, 2012 :agree: :yes: Link to comment Share on other sites More sharing options...
Bhfear Posted June 9, 2012 Share Posted June 9, 2012 Check the Sway Bar End Links as well! Link to comment Share on other sites More sharing options...
foreman1063 Posted June 10, 2012 Share Posted June 10, 2012 The right side lower rear control arm bushing was the culprit on my "87. I bet Link to comment Share on other sites More sharing options...
jeeplover88 Posted June 11, 2012 Author Share Posted June 11, 2012 Thanks for the quick replies guys! Turns out it was my track bar on the right side. It was just a tad bit loose! Thanks so much for your help! :Canadaflag: Link to comment Share on other sites More sharing options...
