Alexia Posted June 14, 2012 Share Posted June 14, 2012 So, the spider gears are toast. Broken teeth, etc. How much of a job is this? googling. . . :peek: The shafts have to be slid out slightly.(Requires removing the brake assembly at least partially.) Fish out and complete remove any debris of the old gears. Slip the new gears into place and push the shafts back into the gears. Helps to have someone hold the gears in place while putting the shafts back into place. This is an abridged version of it, but the process is simple. Link to comment Share on other sites More sharing options...
Dadinator Posted June 14, 2012 Author Share Posted June 14, 2012 So, don't have to remove the ring gear? Link to comment Share on other sites More sharing options...
Pete M Posted June 14, 2012 Share Posted June 14, 2012 only if you had 4.10+ gears. the higher ratios (lower numbers) have enough clearance to get the crossbolt out. :thumbsup: Link to comment Share on other sites More sharing options...
Dadinator Posted June 15, 2012 Author Share Posted June 15, 2012 Guess I'll try it this weekend. thanks for the encouragement. :thumbsup: One more thing... Looking at the parts I need. 30 spline axles? Link to comment Share on other sites More sharing options...
Dadinator Posted July 1, 2012 Author Share Posted July 1, 2012 Got my spider gears. Looks like the ring gear will have to come out. I'm pretty sure it has 3.73 gears, though. But the pin won't clear the ring gear. Crap... Link to comment Share on other sites More sharing options...
Pete M Posted July 1, 2012 Share Posted July 1, 2012 huh. I was told that only 4.10 and deeper needed that. weird. my 4.10s juuuuust barely wouldn't clear. even contemplated grinding a hair outta the gear like some others had done. well, it's still possible for an amateur to do, just infinitely more of a pain in the rear. make sure the bearing caps go back in the exact same orientation they are now, and have your torque wrench specs and locktite handy for installation. oh, and I got my carrier out using 2 crow bars. google should provide other methods if it's really stubborn. :thumbsup: Link to comment Share on other sites More sharing options...
skidoo_j Posted July 1, 2012 Share Posted July 1, 2012 huh. I was told that only 4.10 and deeper needed that. weird. my 4.10s juuuuust barely wouldn't clear. even contemplated grinding a hair outta the gear like some others had done. well, it's still possible for an amateur to do, just infinitely more of a pain in the rear. make sure the bearing caps go back in the exact same orientation they are now, and have your torque wrench specs and locktite handy for installation. oh, and I got my carrier out using 2 crow bars. google should provide other methods if it's really stubborn. :thumbsup: I used a ratchet strap tied through and around the carrier and then attached it to a slide hammer. I was afraid of marring the case/carrier with pry bars. Oh I also tied the strap up to the bed of the truck so that if it bounced out too hard it wouldn't hit the ground... Link to comment Share on other sites More sharing options...
Dadinator Posted July 1, 2012 Author Share Posted July 1, 2012 Already got it out and spiders installed and the carrier back in. Used the 2 crow bar method. Pete, is yours a D44? Maybe that's the difference why it wouldn't clear.. I don't know. Taking lunch. Will post pics in my build thread later. Just have to put the axles back in and button it all up. Link to comment Share on other sites More sharing options...
Pete M Posted July 1, 2012 Share Posted July 1, 2012 I swapped the spiders for a minispool in my 44 front. :thumbsup: Link to comment Share on other sites More sharing options...
Dadinator Posted July 1, 2012 Author Share Posted July 1, 2012 Got the axles back in, brakes back on and the wheels back on. Everything looks good. Off to the parts store to pick up a gasket and some more oil. I don't think I have enough. Then all done. Will finish it tomorrow as it is to bloody hot out there right now. This weather is dumb. :dunce: Link to comment Share on other sites More sharing options...
Dadinator Posted July 1, 2012 Author Share Posted July 1, 2012 Put a few pics on the "Family Truck" build thread of the spider gear replacement. Link is in my sig if interested. Link to comment Share on other sites More sharing options...
