aaronbtxnc Posted May 18, 2012 Share Posted May 18, 2012 Well, time to buy a new toy that will be needed. Recomendations? I see them from about 20 up to 150 and more. What torque range will I need to do axle swap, possible rear main seal replacement, etc. to the MJ? Link to comment Share on other sites More sharing options...
knever3 Posted May 18, 2012 Share Posted May 18, 2012 I bought mine from harbor freight for $20, 1/2" up to 250ft/lbs for the usual work, head gasket jobs, torque wheels etc. I figure for what I am going to be using it for I don't have to pay for a nice one anytime soon. The best $20 I have spent for a tool ever and I am not a fan of harbor freight for much. Link to comment Share on other sites More sharing options...
Geonovast Posted May 19, 2012 Share Posted May 19, 2012 I got a clicker-style PT from O'reillys, one of the few tools of mine that isn't a Craftsman, and I like it. I don't remember how high it goes, don't think it quite goes to 250. I actually haven't been to a Harbor Freight in years, despite there being one less than 2 miles away... should fix that... Link to comment Share on other sites More sharing options...
foreman1063 Posted May 19, 2012 Share Posted May 19, 2012 Don't get a Craftsman torque wrench, they are crap and expensive. An axle swap and RMS replacement will require two different torque wrenches. Oil pan bolts get 11 ft/pounds of torque( best to use an inch/pound wrench and multiply torque value by 12) and doing an axle swap will probably require torques in the 50-150 ft/pounds range. If you plan on working on and maintaining a vehicle you really need an inch/pound, a 3/8" drive ft/pounds and a 1/2" drive ft/pound torque wrench. This will give you flexibility to use a wrench that will keep the required torque in the mid range of each wrench, for better accuracy. Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 19, 2012 Share Posted May 19, 2012 There's cheap torque wrenches, and there's good ones. Decide what you want. The HF/Craftsman/no-name ones are the 'cheap' ones. Some of them work fine, others do not. Very hit and miss. As a general rule, if there's plastic anywhere on it, you don't want it. As far as the good ones go, there's only a few manufacturers actually. I personally like the ones sold by Armstrong, Mac and Finning, I want to say they're made by Precision Instruments (but maybe they make the Snap-On ones), since I find they have the best adjusting systems and grips. For good ones, I own a Snap-On 40-200IN-LBS, a Finning flex head 5-75FT-LBS, and an Armstrong 25-250FT-LBS. I also have a Craftsman 1/2" drive, that I rarely use. It still works okay, and calibrated as 'not too bad', but I rarely use it. Eventually the adjusting mechanism breaks on them. Link to comment Share on other sites More sharing options...
87Warrior Posted May 19, 2012 Share Posted May 19, 2012 I grew up using my father's Snap On click torque wrenches so that fit and function is what I was looking for when searching for one. The problem was I didn't have the cash for a snap on unit. I went to all stores and even to a few tool trucks. I feel the best bang for the buck torque wrench is the Husky Pro from Home Depot. Pretty darn cheap and I love the way it works. Link to comment Share on other sites More sharing options...
