veritas4156 Posted April 30, 2012 Share Posted April 30, 2012 Alright, so my alternator just seized up and I need to replace it, however all of the auto parts stores that I check seem to only have a 90 amp alternator, which is what I believed should be correct. However, my build sheet from chrysler lists a "BAFP 130 Amp Alternator". Does this even exist? If so, where do I get this? I don't want to downgrade because my alternator went out. Link to comment Share on other sites More sharing options...
MJRemi Posted April 30, 2012 Share Posted April 30, 2012 I recently bought a new one from Autozone and they had several to choose from. I ended up getting a 100 amp which is plenty since I don't run auxiliary equipment. Bring the old one with you to avoid core charges and to compare the bolt pattern. They first sold me the one for a 2.5 which I didn't realize until I tried installing it. Link to comment Share on other sites More sharing options...
veritas4156 Posted May 1, 2012 Author Share Posted May 1, 2012 The only options I saw at autozone or advance or anything is a difference between new or reman. Link to comment Share on other sites More sharing options...
carnuck Posted June 7, 2012 Share Posted June 7, 2012 Check the Cherokee listing. Napa did the same goof. Link to comment Share on other sites More sharing options...
veritas4156 Posted June 7, 2012 Author Share Posted June 7, 2012 I already checked. Hmm... Maybe they made a goof on my build sheet? Did comanches ever have 130amp alternators? Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 7, 2012 Share Posted June 7, 2012 Goof on the build sheet - mine said the same when I had the 90A alt. Since you have a 91, a good upgrade is the Nippon-Denso 136A ZJ/Dodge alternator. Was an easy bolt-in for me. http://www.vicic.com.tw/alternators/gVDN11361204.htm Link to comment Share on other sites More sharing options...
veritas4156 Posted June 7, 2012 Author Share Posted June 7, 2012 I assumed that was what they put in it since they said 130 Amp. I'll have to pull it out and check it out, but thanks for the heads up. Odd that they would mess up like that. I should go to my dodge dealer and tell them "Hey, my build sheet says 130A and this one is only 90!" I'm still on the original brake rotors, maybe I'll try for that recall too... Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 7, 2012 Share Posted June 7, 2012 If the tag is still there, you can see the p/n with a mirror, 56005685. That's the 90A alternator. From the factory, I've never seen anything other than a 90A alt on the 91-92 MJs. Link to comment Share on other sites More sharing options...
veritas4156 Posted June 7, 2012 Author Share Posted June 7, 2012 Its bad, so I'm pulling it out anyway. If its something else, I'll post pics and let you know. Link to comment Share on other sites More sharing options...
Rohls Posted November 25, 2014 Share Posted November 25, 2014 Goof on the build sheet - mine said the same when I had the 90A alt. Since you have a 91, a good upgrade is the Nippon-Denso 136A ZJ/Dodge alternator. Was an easy bolt-in for me. http://www.vicic.com.tw/alternators/gVDN11361204.htm Hi Hornbrod, i know this is an old thread...would the Nippon Denso 136A described above be the choice for my 1992 MJ 4.0 upgrade from stock? I don't think the above link works... Thanks! Link to comment Share on other sites More sharing options...
ggcnash Posted November 25, 2014 Share Posted November 25, 2014 Goof on the build sheet - mine said the same when I had the 90A alt. Since you have a 91, a good upgrade is the Nippon-Denso 136A ZJ/Dodge alternator. Was an easy bolt-in for me. http://www.vicic.com.tw/alternators/gVDN11361204.htm Hi Hornbrod, i know this is an old thread...would the Nippon Denso 136A described above be the choice for my 1992 MJ 4.0 upgrade from stock? I don't think the above link works... Thanks! Not trying to speak for Hornbrod but there are several writeups on this. I've done it to my 91 which required some minor grinding to bracket, but helped my buddy on his 92 xj that didn't require any grinding. I may be mistaken but I think Hornbrod has posted that his 91 required no grinding go figure. To answer your question it works great either way I would look in to upgrading your cables why your at it good luck. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 25, 2014 Share Posted November 25, 2014 ^^ Yes, everything ggcnash said. No grinding was required for me. Good upgrade, and yes, replace your mains cables at the same time. HERE Link to comment Share on other sites More sharing options...
Rohls Posted November 26, 2014 Share Posted November 26, 2014 ^^ Yes, everything ggcnash said. No grinding was required for me. Good upgrade, and yes, replace your mains cables at the same time. HERE Thanks! Will do. Link to comment Share on other sites More sharing options...
