installed my ax-15,
i have 2 x-members that are stock and they don't entirely line up,
I'm using the back mounts for the x-member,
the furthest back line up, the front holes on x-member do not,
they are 1" to far forward,
has any one had this problem??
if so, what x-member do i need to fix this?
installed my ax-15,
can you post pics of what you're seeing? are they AX-15 crossmembers?
this may sound a little stupid but, is the rubber mount on the correct way? I also noticed the rubber part can be put on backwards (rotated 180 degrees) and move the x-member by about an inch left to right. there are 2 sets of mounting holes for x-members. My BA-10 used one set, and the AX-15 used the other. is the crossmember backwards?
no sir,
i had to grind the stock bolts off the cherokee's extra cross brace just to take it off
x-member is almost identical to the one i took off the tranny on the right
Neither of those pictures can reveal if it's an AX-15 crossmember, but from how the mount looks in the second picture, I am betting it is not.
Yes, the way you can ID the diff between the AX-15 and AW4 (which I think you have) crossmembers is the center section. Looking at it from the top, the AX-15 dips down about 3/4" while the AW4 has no dip; it's straight across. Also the right side indent for the exhaust pipe is formed differently. I've just been through all of this trying to drop the tranny w. an AX-15 member, but it caused my exhaust pipe to rub due to the headers.
Yes it has the 5/8 dip,
Found out my problem, lpaint + dirt and rust covered the other mounting holes,
Got it mounted, and went snaaap, all the threads toast,
Just got back with my helicoil kit :yes:
