captainkettel Posted December 29, 2005 Posted December 29, 2005 Will a Dana 44 assembly out of a 1987 Jeep Cherokee fit (work) with my 1986 Comanche? The unit is complete with housing, brake cables and even the rear brakes and drums. Is this the same as a metric ton rear end? I'm not planning any real hard core off roading, but would like the additional load carrying and axle strength for some larger (33) tires for the lift.
DirtyComanche Posted December 29, 2005 Posted December 29, 2005 It's all dandy, but it has to match your front gear ratio. And the spring perches will be slightly the wrong width, plus on the top of the tubes instead of the bottom.
mjeff87 Posted December 29, 2005 Posted December 29, 2005 Just like DirtyComanche said, plus the shock mounts are in the wrong place. You'll have to incorpoate new ones to go along with new spring pads. I got an XJ one out of the junkyard last month to swap into my MJ, but I'm trading a local guy even up for an extra MJ one he has so I won't have to worry about all that :D I just have to regear it to match the front. Jeff
whowey Posted December 29, 2005 Posted December 29, 2005 If you are looking for the extra load capacity, you will also need beefier rear springs.
pingpong Posted December 29, 2005 Posted December 29, 2005 Just swap in a 8.8 with discs and 4.10's and regear the front, you will come out money ahead and have a stronger axle
DirtyComanche Posted December 29, 2005 Posted December 29, 2005 Depends on how cheap he can get an 8.8. The D44 isn't bad, weak tubes though. If he's only going to run 33s it should work out... If larger than 33s, you might as well look at all the other options, ie fullwidths.
