dual batteries
i plan on running dual batteries but i wanted to see if this would work in an mj, also how do i find out the out put of my alternator
http://www.ase-supply.com/product_p/1202.htm
That's a great price, I like the design of this tray but at nearly $500....
http://www.wranglernw.com/ProductPicker ... temtype=11
I think with factory air you get the higher (90 AMP?) alternator, but I am sure someone else has more accurate knowledge of this.
Theres a link and write up somewhere on the net that shows how to do a somewaht factory dual battery setup...
It uses the battery tray from an Austrailan RHD XJ. Everything bolts right up..
And yes you do have to remove the airbox and replace it with a cone or something like that...
I just say it a few days ago, but can't seem to find it now...
The other option is to run dual batteries in the back of the box in a Tool box of sorts...
Ryan
yeah, there was a high and low output alternator, the high is 90 or 105 or something like that,
and the low is like 60 IIRC
what's the benefit of a second battery? just extra insurance?
if you're running a winch the second battery is a great thing.
good point, winching does tend to drain on my bro's XJ
It is good insurance too. I used to fry my red tops all the time cause of my crappy charging system, so a back-up walmart battery was always nice to have. With the isolator, the back-up battery always stays charged, so you don't have to worry about it going bad like you would have to on a back-up that you were just storing. Also, they're nice for campers, which I suppose is the main reason I had mine.
According to my handy MJ parts manual, stock alternators are as follows:
4 cylinder: 74A
6 cylinder: 100A
V6: 78A
Diesel: 70A
I found a NOS 93-97 Denso G. Cherokee 120A alternator (from a Jeep delearship) on Ebay for $29. Same size as my 90A. Swapped the front pulley and the plastic tailpiece and it bolted right in. Good upgrade............
